Old 12-05-2006, 04:51 PM   #1
ktlx1
Question Voltage Issue Help Please
All, my voltmeter (Autometer) guage is registering 16.0 volts, I replaced the regulator and no change. Any thoughts on what to check to see where the issue is
ktlx1 is offline   Reply With Quote
Old 12-05-2006, 05:00 PM   #2
shifty
Questionable
shifty's Avatar
Re: Voltage Issue Help Please
Make sure the only line from your alternator to your battery passes through the voltage regulator. Double-check your connections to the regulator to make sure it's actually passing through the regulator
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 12-05-2006, 05:04 PM   #3
shifty
Questionable
shifty's Avatar
PS - Pretty sure you should test the voltage where the lead from the regulator terminates at the battery.
Old 12-05-2006, 05:20 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Also,if you have one check voltage at the batt while running.It should show around 14 volts or so.There are 2.2 volts per cell in a 12 volt batt so it should show 13.2 if it's fully charged.With it running it should be around 14 volts.You may just have a gage problem but if not your batt is overcharging.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-06-2006, 05:26 PM   #5
KTLX
All, thanks very much, off to check the suggestions.
Kenny
KTLX is offline   Reply With Quote
