Old 12-05-2006, 09:58 PM   #1
masterbeavis
Having issues
masterbeavis's Avatar
Any interest in K20 misc frame pieces?
Parting out a 71, have the frame left.(minus eng and trans cross member) I need to haul it off to the scrapyard here in a bit, was wondering if there was any interest in portions of the frame?
masterbeavis is offline   Reply With Quote
Old 12-05-2006, 10:15 PM   #2
msgross
msgross's Avatar
Re: Any interest in K20 misc frame pieces?
yep, can you help me out with this piece? Not sure if yours is the same but mine is a K-10 SWB..thanks... Here is the thread with my pics and issue... shipping would be to 17042 and I only need the small part.
http://67-72chevytrucks.com/vboard/s...d.php?t=218061
msgross is offline   Reply With Quote
Old 12-06-2006, 12:05 AM   #3
masterbeavis
Having issues
These? They are not going to be fun to remove I will see what happens.
Old 12-06-2006, 12:12 AM   #4
1969k10stepside
I need a motor mount/crossmember but since you are not selling it I will keep looking.I might need a piece no bigger than 4"X4" out of the very back crossmember from about the middle all the way up the 90 degree angle.I might still have a piece off a frame I scrapped but I might have already hauled it away.
1969k10stepside is offline   Reply With Quote
Old 12-06-2006, 12:18 AM   #5
masterbeavis
Having issues
you will have to show me a picture of what you want, is it in one of MSGross' pics in the thread he linked? Right click, save as, load up in MSPaint, draw a circle on what part you need.
Old 12-06-2006, 12:20 AM   #6
1969k10stepside
No,I dont have any pics on my computer right now but I can get a pic of what I need tomorrow.I might also need a set of brackets that are riveted to the frame which IIRC are for brake lines.You will probably just have to wait till I get some pics
Old 12-06-2006, 09:32 AM   #7
msgross
msgross's Avatar
I only need the driver side lower piece, let me check to be sure I don't need the pass side. You should be able to grind an "X" into the rivets and knick them off with an air chisel. If it's easier I can take the entire piece, up to you. Thanks...
Old 12-06-2006, 11:29 AM   #8
BobS
BobS's Avatar
Are the spring mounts available?
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 12-06-2006, 10:19 PM   #9
masterbeavis
Having issues
BobS: yes, front or rear?
MSGross: it depends on how easy things come off. If it pisses me off bad enough, you might get part of the crossmember, and frame.
Old 12-06-2006, 10:27 PM   #10
msgross
msgross's Avatar
haha..
what about the frame piece that supports the power steering pump? I have seen threads where they welded that over my 68 frame to attach a newer PS box....
This is a borrowed pic of what I am talking about. He said he welded the outer piece onto the 67-68 frame. Mine doesn't have the dimple for the PS box.
Old 12-06-2006, 11:19 PM   #11
masterbeavis
Having issues
Uh, beats me, I have not removed the steering gear yet.
Old 12-07-2006, 01:12 AM   #12
Rod
I couldnt find anyone piecing out a frame earlier this year...now there coming out of the woodwork with the season changing. I dragged a stripped down chassis here, but I was missing the same engine and tranny cross members too.
Rod is offline   Reply With Quote
Old 12-07-2006, 10:19 AM   #13
BobS
BobS's Avatar
Front/Fronts and Rear/Rears for the spring mounts.
Bob
66 GMC 1000-V6
66 GMC 1500-V6
68 GMC C1500-V6
68 GMC C1500-V6
70 Chevy K20-SBC
72 Chevy C10-SBC
Old 12-07-2006, 03:09 PM   #14
msgross
msgross's Avatar
I take it that you plan on keeping the steering box, when you remove it I would like the area that it bolts to. Quick cut of the torch a few inches behind the back and in front of the front holes will do. let me know...thanks.
Old 12-07-2006, 08:35 PM   #15
manimal
manimal's Avatar
is the frame totalled? or is it in good "builder" shape? I may be interested in the whole thing.Where is Eldorado at? I live in Cherry Valley,Ca(by SanBernardino)
manimal is offline   Reply With Quote
Old 12-07-2006, 09:05 PM   #16
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Eldorado is about 1 hour north of sacramento, off the 50 freeway, I believe.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 12-07-2006, 09:11 PM   #17
Blue_71
Bloo
Blue_71's Avatar
if they're available id be interested (pending on price shipped to 42141) in the rear/front spring mounts.
to be specific, the four little metal straps, and the peice that mounts inside the frame for the bolt to go through. i cant remember if its bolted or rivited.
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 12-08-2006, 12:20 AM   #18
masterbeavis
Having issues
Manimal, if you want the entire frame, you can PM me, we can work out a price. Nothing is missing yet aside from the bracket for the clutch linkage. The frame will clean up and look like new, with no need for fixing rust holes.
Old 12-12-2006, 01:20 AM   #19
masterbeavis
Having issues
ttt
Old 12-12-2006, 02:08 AM   #20
earl87gta
earl87gta's Avatar
put me in line for the front spring mounts.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 12-12-2006, 10:54 AM   #21
msgross
msgross's Avatar
any update on the parts?
Old 12-13-2006, 02:07 AM   #22
masterbeavis
Having issues
Yes, waiting on somebody to buy the entire frame. Probably isn't going to happen, have had a few people say "Dont cut it up, I want it" but they dont put their money where their mouth is.
Old 12-13-2006, 03:44 AM   #23
4bynut
4bynut's Avatar
Originally Posted by msgross View Post
haha..
Hey, that's the frame on my 67 (HA HA). Don't forget to put spacers in between the original frame and the frame section you weld on. Sorry i dont have pics of the piece before i welded it on to the original frame. I used big nuts that the gear box bolts would pass though. I welded them to the small frame section your putting over the original. I'll post a few more pics in the other thread. Thanks Jason
P.S. Masterbeavis, i need the box brackets if you part out the frame. I'll get pics tomorrow. Thanks Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans.
2001 Chevy ZR2 Ext. cab 4x4 (DD)
1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process)
1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project)
4bynut is offline   Reply With Quote
Old 06-19-2007, 06:07 PM   #24
masterbeavis
Having issues
I am cutting it up today. Front spring hangars, and motor/trans cross members are gone
Old 06-21-2007, 04:57 PM   #25
BobS
BobS's Avatar
Can I get the rear spring hangers?
Bob
66 GMC 1000-V6
66 GMC 1500-V6
68 GMC C1500-V6
68 GMC C1500-V6
70 Chevy K20-SBC
72 Chevy C10-SBC
