Old 12-06-2006, 08:05 AM   #1
70c10
67-72 Addict!
70c10's Avatar
Disc brake pads????
I'm in the process of converting my truck to disc brakes and I'm curious about the pads that came in the kit. The backside pad came with a spring clip to attach it to the caliper but the frontside pad has no clip and it just lays in there . This doesn't seem right to me. When I rotate the disc it's flopping around and making a rubbing noise. Does this pad seat itself somehow after the brakes are bled or is it missing a clip????. I'm thinking about going to the parts store and having them pull a set of pads for a 71' so I can compare them to what I have.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-06-2006, 08:36 AM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: Disc brake pads????
After searching I found this pic which must be correct because it looks like my setup. Part number 8 holds that backside on but part number 5 is what's wiggling around loose. If I remove the caliper assembly that pad will fall out on it's own. Are the 2 little ears bendable to get them to hold on? Can somebody please shed some light?
Jim
Old 12-06-2006, 09:15 AM   #3
jamon8
jamon8's Avatar
no clip on the outside pad
jamon8 is offline   Reply With Quote
Old 12-06-2006, 11:18 AM   #4
Bob Moore
The outer pad has little tabs on the top towards each end. Use channel locks to crimp them on the caliper. Also the anti-squeal goo.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 12-06-2006, 12:00 PM   #5
Brad
Out of the carpool lane.
Brad's Avatar
The outer pad just sits in there. Once you get everything bolted on it should be snug up against the roter and basically just float there. It sounds as if there's no fluid pushing #10 and the caliper up against the rotor yet.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 12-06-2006, 12:11 PM   #6
70c10
67-72 Addict!
70c10's Avatar
Bob- I didn't realize the tabs were supposed to be crimped but that makes sense.
Brad- We only have one side done so far, you are correct in that nothing has been tested yet.
Jim
Old 12-06-2006, 05:26 PM   #7
70GMCer
70GMCer's Avatar
Hey Jim, remember what I said about this. Everything will work fine when we finish this.....Relax!!
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 12-06-2006, 08:30 PM   #8
70c10
67-72 Addict!
70c10's Avatar
LOL Steve!. I'm just not used to these pads. I mounted the wheel to check for clearance of the wheel weights at the spindle and it's super close!. I'm going to buzz the spindle with the grinder for a tad more clearance. I also found my tube bender to do the brake line!.
Jim
Old 12-06-2006, 10:22 PM   #9
kelsfine69
18 Till I Die
kelsfine69's Avatar
Have a person in the cab. Take a little pry bar and push the pad up away from the center of the rotor( create as much space as you can between the tabs and the caliper). Have your helper push on the pedal hard to hold the pad against the rotor. While they hold the pedal down take a big flat punch and hammer and hit the tabs till they hit the caliper. This guarantees the pad is held in there tight to prevent squealing. Also ad a little film of anti squeal to the back sides of the pads and let it set up a bit before installing (20 min)
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
