Old 12-06-2006, 11:28 AM   #1
HotRod73
HotRod73's Avatar
New Fuel Gauge?
My fuel guage in my truck is crap. Its a 73. It doesnt read right and it always moves around untill i come to a stock not a lot just a little bit, i cant ever really tell how much gas i have... i am wanting to install a new fuel gauge (unless someone can tell me how to fix this one) how do i go about adding another fuel gauge? i dont know how to hook them up, do i need mechanical or electrical. I will just mount it on my dash somewhere...
HotRod73 is offline   Reply With Quote
Old 12-06-2006, 08:58 PM   #2
mhicks
mhicks's Avatar
Re: New Fuel Gauge?
There are several NOS on ebay in the "Buy it Now" section for $25.01. I would think your problem would be a bad ground or gauge.
mhicks is offline   Reply With Quote
Old 12-07-2006, 12:36 AM   #3
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: New Fuel Gauge?
Sounds like you may have a loose connection.
The fuel gauge has three terminals. One terminal is the ground, another terminal is the source (+12 V) and the third one is the signal coming from the sending unit in the tank. If the connections behind the gauge are good as well as the gauge terminals then check the signal wiring/connections running between the gauge and the sending unit. If all checks out, you could check the gauge to see if it is functioning correctly. Supply a 12V between the source and ground terminals. The fuel gauge should register full when a 90 ohm resistor placed across the signal and ground terminals. It should read half full when a 45 ohm resistor is used (and so on). If your fuel gauge is functioning correctly then it may be your sending unit. You would have to pull the unit out of the tank to check its' operation. Use a meter between the ground and signal terminals of the sending unit to check the resistance as you move the sending unit arm. The meter should read between 0 and 90 ohms, You may also want to check the mechanical condition of the sending unit.
If you need to replace the fuel gauge, you'll need a 90 ohm unit.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
