Old 12-06-2006, 02:34 PM   #1
bulkin'up73chevy
bulkin'up73chevy's Avatar
Block numbers and input on a build
So I have this block number 397 9918 Is it a 350 or a 305 block I don't have a chart or anything so I have no Idea. Or there is a number 41 next it printed on the block.
So I am currently building my 4-wheel drive and I got this for the build rv2 cam edlebrock performer intake HEI distributor, edelbrock 650 carb. I understand this is about a 300 horsepower build. Am I right?? Or what should I expect. I have all the stuff needed to tune it right. What can I expect guys. Haven't been on in a long time.
FAMILY MAN
77 CHEVY LB 4X4
78 GMC LB 4X4 "TOWED AWAY"
77 GMC FLATBED 502 CADDY BB.
85 CHEVY BLAZER (wrecked)
86 CHEVY LB 2WD 77,000 ORIGINAL MILES
86 RX7 "SOLD"
88 RX7 "SOLD"
88 SUPRA "SCRAPPED" DIVORCE SUCKS
2003 HONDA CBR 600 F4I "SOLD" DIVORCE SUCKS
bulkin'up73chevy is offline   Reply With Quote
Old 12-06-2006, 03:51 PM   #2
hiway
Mad Scientist
Re: Block numbers and input on a build
http://www.mortec.com/castnum.htm (for casting numbers)
Depends on cam specs, head, and such. Good start though.
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 12-06-2006, 05:25 PM   #3
bulkin'up73chevy
194 regular cast iron heads I don't know the specific cam specs just its in the rv2 catagory is what it is going to be and I'm thinking steel crank??
FAMILY MAN
77 CHEVY LB 4X4
86 RX7 "SOLD"
88 RX7 "SOLD"
Old 12-06-2006, 06:25 PM   #4
hiway
Mad Scientist
I didn't see your number block on the list. Anyway, a 350 with smog type big chamber heads, flat top pistons, decent rv cam, your mentioned induction, and some headers should make 300hp or close. More important is that it'll have good low end torque for your 4x4.
07 Suburban
02 Danger Ranger
Old 12-07-2006, 06:24 AM   #5
Billla
Billla's Avatar
The intake and carb choice are fine. I'm not sure what the "RV2" cam is - do you have specifics? 300 HP will require 9.2 - 9.5 CR and some fairly decent heads.
Billla is offline   Reply With Quote
Old 12-07-2006, 07:04 PM   #6
lurch115
lurch115's Avatar
that casting number isn't on the list.... but another place you can also look on the block is on either side of it....there should be a 3 digit casting number...what would also help is if you could describe it a little more....like what year the vehicle it came out of was....as for the parts you have...should make a nice motor...we just resently put a Lunati RV2 cam in a friend of mine's truck and although it sounded stock it was far from it....it is a 4X4 with a 4spd and he can light up 35's though all 4 gears.... not to meantion pulling a loaded semi out of amuddy field.... :nut: :happy:
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 12-08-2006, 01:24 AM   #7
bulkin'up73chevy
nice lurch thanks guys for the info. Yah I don't know the specs but the heads are 194's that's all I know. Yah it's a fully locked up 4-wheel drive lurch blazer. And I found the block it's a 350. Putting new crank bearings in tomorrow and putting it all back together and in the truck hopefully have it running by midnight.
FAMILY MAN
77 CHEVY LB 4X4
86 RX7 "SOLD"
88 RX7 "SOLD"
Old 12-13-2006, 02:58 PM   #8
jr2
jr2's Avatar
I'd be willing to bet the casting # is actually 3970010...Look again...
-John II
"A Little's Good! A Lot's Better! & Too Much is Just Right!!"
-1978 Chevy C10 Stepside 350/4sp/12 bolt
-1967 Nova 2dr HT & a couple others...
jr2 is offline   Reply With Quote
