Old 12-06-2006, 05:51 PM   #1
1971-tetanus-shot
How much lift do you get with firestone 2600?
I am figuring out the front suspension setup ( 71 C20 longbed) and I need to know roughly how many inchs will the front lift with Firestone 2600 bags, I am running a small block (All stock so far) with th400 trans. I know it varies with air pressure and weight but thats why I am asking rough guess from others experience
1971-tetanus-shot is offline   Reply With Quote
Old 12-06-2006, 11:44 PM   #2
leftcoast66
leftcoast66's Avatar
Re: How much lift do you get with firestone 2600?
bout 7 or so inches at max, usually mine only goes up about 4 or 5 inches at most since it doesn't need to go much more on my truck.
leftcoast66 is offline   Reply With Quote
Old 12-07-2006, 12:15 AM   #3
Shane
Shane's Avatar
Approx. 6"-7" is what I get from 2,500 lb. Firestone's on the front.
Shane is offline   Reply With Quote
Old 12-13-2006, 12:28 PM   #4
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
I had 2600s on my 88 and they lifted from the frame on the ground to the upper control arms against the frame on 150lbs of nitrogen.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 12-13-2006, 03:35 PM   #5
laidout69
laidout69's Avatar
heres mine wit firestone 2,600 now i have installed slams if u want more lift go with slams.
1969 chevy
bagged, fully shaved still UnDeRcOnStRuCtIoN
laidout69 is offline   Reply With Quote
Old 12-13-2006, 11:09 PM   #6
bagged70
you get 6inches with firestone and 8 with slams best thing is that slam are nonballoning but firestone are
bagged70 is offline   Reply With Quote
Old 12-14-2006, 02:08 PM   #7
pharcyde05
pharcyde05's Avatar
this came from Suspension Connection
Air Spring Replacement - Firestone Air Bags:
Double Convoluted Air Spring - Ride Height 5"-6.5" / Max. Diameter 8" / 3/8 NPT Air Inlet - EACH
Firestone air springs and accessories are the preferred choice of the street vehicle enthusiast who demands quality and ride performance. With highly engineered air springs and components.
Ride height 5.0" - 6.50"
Max Diameter 8"
3/8 NPT Air inlet
2500 lbs at 100 PSI
pharcyde05 is offline   Reply With Quote
