12-06-2006, 07:27 PM | #1 |
71 Chevy
G87 Powerloc diff
This is the rear end code for the truck I bought last week. Are they any good? I saw a post today and somebody said that the G80 diffs were basically garbage, is this one in the same family? Also it does not have a ratio listed does any one have a quess as to what it may be? I have not driven it yet so I am clueless as to what RPM's it turns. It is on a 3/4 ton so my guess would be 4:10 or 4:56.
71 C10 72 C20 62 Chevy II 2DR HT |
12-06-2006, 11:14 PM | #2 |
Re: G87 Powerloc diff
G87 is a dana 60 with a powerlock... Very nice.
It should be either 3.54 or 4.10 gears |
12-06-2006, 11:29 PM | #3 | |
70 GMC shortbed fleetside with a 72 chevy costume Last edited by 72dually; 12-06-2006 at 11:34 PM. |
12-07-2006, 01:12 AM | #4 |
ASE Certified Spoon Operator
well, crap. I have a G80 positrac in a parts truck, is there a definite way to tell if it's junk or not? It's a 4.11 ratio BTW...
My six is bigger than your eight 67 K20 292 +.060" SM465 NP203 3.73s 86 4Runner, the daily on 31s 85 4Runner, the wheeler on 38s 92 x-cab truggy project for 2017... tons and 42s and V8 power |
12-07-2006, 08:08 AM | #5 |
If it is from the '67 - '72 era, a G80 is a normal Eaton limited slip (posi). Sometime in the mid '70s GM switched to the Eaton automatic locker ("gov-lock") while still using the G80 RPO code. The gov-lock is the one that people don't like.
Tim |
12-07-2006, 08:19 AM | #6 |
71 Chevy
The one on the truck is original so it must be the '67 - '72 era normal Eaton limited slip (posi). I am assuming that it must be a Dana since it is not an HO52.
12-07-2006, 04:53 PM | #7 |
Yours, with a Dana 60 and the G87 option is a Dana Powerlock which is also a limited slip. The Eaton limited slip was used in the corporate axles (12 bolt and in later years the 10 bolt).
Tim |
12-07-2006, 05:20 PM | #8 |
Yeppers, and both units are very reliable
70 GMC shortbed fleetside with a 72 chevy costume |
