Old 12-06-2006, 11:34 PM   #1
DANL
Rear Sway Bar Recommendations
My 72 K5 has some body roll, not bad but noticeable. The shocks and springs seem to be in good shape so I am considering a rear sway bar. The ideal bar would be a bolt on that does not require any mods. Let me know if you have any recommendations or thoughts
Thanks in advance.
...Dan
DANL is offline   Reply With Quote
Old 12-07-2006, 09:02 AM   #2
-Greg72
-Greg72's Avatar
Re: Rear Sway Bar Recommendations
No mods???
.....what fun is THAT!?
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s
Find me on INSTAGRAM @MIGHTASWELLK5
'72 K5 - Greg's "Might As Well™" Build
-Greg72 is offline   Reply With Quote
Old 12-07-2006, 08:51 PM   #3
see ten
WTB this ad
see ten's Avatar
Do you already have one on the front? If not adding one out back is a no no. It seems like later model 4x4 suburbans have swaybars front and back. I would think they would make a good donor for a near bolt on.
see ten is offline   Reply With Quote
Old 12-07-2006, 11:12 PM   #4
DANL
Hey Guys, thanks for the responses. I would be doing good at getting a bolt on installed without mods. I do not have one on the front. I may check out the later burbs. I guess 73-88 would be the closest.
Thanks again.
...Dan
Old 12-09-2006, 09:18 AM   #5
DANL
Any other recommendations for OEM type that will bolt on without mods? I have looked at LMC, PST, Industries and Hellwig. LMC and Industries indicates a 7/8" but not certain if it will require mods. Hellwig has discontinued and PST doesn't list one.
...Dan
Old 12-09-2006, 04:27 PM   #6
leftcoast66
leftcoast66's Avatar
Check out Brotherstrucks.com I know they have front atleast and I'm pretty sure bars for the rear as well.
leftcoast66 is offline   Reply With Quote
Old 12-11-2006, 01:30 AM   #7
Low68
Low68's Avatar
I once ran a Hellwig sway bar on the back of my truck. It was a complete bolt on and used clamps to hold onto the frame, with no hole drilling required. You say that sounds cheap? Right you are. One of the mounts fell off...sometime....somewhere. Never figured out where it fell off. Maybe that is why they are discontinued.
Check out No Limit. I think their website is nolimit.net.
Build Thread
Low68 is offline   Reply With Quote
Old 12-11-2006, 01:32 AM   #8
Low68
Low68's Avatar
Oh by the way, if anybody ever had a sway bar mount go flying into the front of your car or anything, its not mine.
Build Thread
Old 12-31-2006, 12:55 AM   #9
DANL
Left, brothers list ADDF141 for the frot of a 72 k5.
Low, nolimit list one for the rear of a 72 K5.
I have sent both an email for application and mod verification.
Would you install front first then back if front does not correct all roll and over steer?
Thanks again.
...Dan
Old 12-31-2006, 11:34 AM   #10
-Greg72
-Greg72's Avatar
Front sway bar increases understeer......thicker bars mean more understeer.
Rear bar (after front is installed) will begin to balance the truck by removing understeering qualities and give the vehicle a more neutral balance in the corners....adding thicker bars out back will eventually make it tail-happy...
Having at least one of the bars adjustable is nice, because you can dial-in the handling behavior you want by softening or stiffening the bar.
Old 12-31-2006, 11:09 PM   #11
DANL
Hey Greg, not sure if I have under steer. I have to continuously adjust my steering wheel, tiny amounts, in both directions while driving at 55 mph. Also I can feel the body roll when making lane changes. All steering components and shocks are new with less than 5k miles. Springs are stock originals.
I had originally thought the sway bars might be the answer. However now it appears to be more complicated than I originally thought.
Thanks for the feedback.
...Dan
Old 01-01-2007, 09:39 PM   #12
-Greg72
-Greg72's Avatar
My worn drag link ends on my stock push/pull steering setup caused a similar issue (the vague wandering)....could be slop in the steering box too....or alignment (toe in/out) or a bad set of tires...
Understeer is more of a behaviour at the limits of cornering....the front end wants to continue to go straight in a corner, even though the steering wheel is asking it to turn.
A front sway bar will add some "crispness" to your turning, and for quick transitions from left to right. The wandering sounds like some other issue that you need to sort out separately though...
Old 01-02-2007, 10:59 PM   #13
DANL
New steering box and drag link ends with a recent alignment. Inexpensive low mileage tires that are five years old. May initially focus on tires and spring bushings.
Thanks again for the comments Greg.
...Dan
