Old 12-07-2006, 01:32 PM   #1
laughinbear
3/4 to 1/2 ton conversion
hello i just bought a 3/4 ton chevy it has 8 lug wheels has anyone converted to a 5 lug set up if so what did it take?
laughinbear is offline   Reply With Quote
Old 12-07-2006, 01:45 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 3/4 to 1/2 ton conversion
welcome to the forum from central ohio
Does your 3/4 ton have coils or leafs in back?
Up front, the easiest way to to do an entire crossmember swap from a 71 - 87, the later onew will be metric, but otherwise almost a direct swap. You'll have to egg or waller out a couple holes, but otherwise a simple remove and install.
The rear, just swap out for lighter duty springs, and a rear axle from a 71/72 if coil, or a 71 - 87 leaf spring rear.
