12-07-2006, 08:01 PM | #1 |
Noobie McNoobster
Broken Flexplate
Well I had been hearing this tapping sound in my 68 K20 for a few days, then it started knocking and that went from knocking to hammering. I thought for sure that the bottom end was going south. So I removed the inspection cover and look what I found.
Any thoughts on what the easiest method to replace the fledxpate would be? e.g. removing tranny and xfer, or pulling engine? Thanks.
The Stable: 1968 Chevy K20 w/tilt, working AM/FM, AC and 350/350/205 w/Disk Brakes 1990 Chevy V2500 Suburban 2005 Kawi KLR650 1983 Honda Goldwing GL1100 Standard (Naked) 1995 Miata M Fortes Fortuna adiuvat |
12-07-2006, 08:05 PM | #2 |
Gone Fishing
Re: Broken Flexplate
I have done this a couple of times on my 2wd and just dropped the tranny
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
12-07-2006, 08:15 PM | #3 |
67-72 parts finder
if it was me i'd drop the trans with crossmember and the transfer case and you can get right to it, might think about buyin a heavy duty flexplate too so it doesn't happen again, i had an el camino that busted them like crazy, and its not all that fun of a job especially in a 4x4, on 2wd vehicles i never drop the trans completely i just schoot it back enough to pust the convertor in and take it off with an end wrench you don't need all that much room, well hope i've been helpful for ya
1969 chevy shortstep 2wd (under construction) 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
12-07-2006, 08:16 PM | #4 | |
20' Daredevil (Ret)
A semi-retired mechanic pulled the t-case and the trans to replace the flexplate. Worked his @$$ off and felt bad about the number of hours, and gave me a break on the cost -- then said he hoped he never had to do another one!
12-07-2006, 08:23 PM | #5 |
Fabricate till you "puke"
Pull the fan off the front, take the eng mounts loose, exhaust, ect....leave the /transfer case in place, just slide the eng ahead. you wont need to pull it, but i have done it both ways , & IMO its easier sliding the eng foward... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-07-2006, 08:25 PM | #6 |
Noobie McNoobster
That is exactly what I was thinking, I was just curious if someone else had done it that way.
