Old 12-07-2006, 08:03 PM   #1
1969k10stepside
Another lift kit question..
Ok,Im getting close to the part of my project where the lift kit goes on.My rear springs are junk so I am wanting to just get a lift kit with rear springs.I am leaning on going with a 4 inch lift and 35's for it.My question is which lift kit would be good for a swb 71 K10 in a 4 inch lift with all 4 new springs?It had a 6 inch lift on it but I thought it was a little to big for it.Where is the best place to buy them and how much does a lift kit with all 4 new springs usually cost?Does a 4 inch all spring lift have a shackel flip because I am leaning against that?Also do they require the spring hangers to moved?The lift that was on it required the rear hangers to be moved.The truck will be a D.D./ Garage Queen /off roader in its spare time.
1969k10stepside is offline   Reply With Quote
Old 12-07-2006, 08:22 PM   #2
Zoomad75
K5Camper
Zoomad75's Avatar
Re: Another lift kit question..
all spring kits are just that. They don't incorporate a shackle flip. Most shackle flips net 4" by themselves with stock springs, so if you added a 4" spring on top of that you would double what your front springs lifted the truck.
I've never heard of an all spring lift that required movement of the spring hangers. Something don't sound right there. 99.9% of leaf spring lifts bolt right into the existing spring mounts. If the 6 inch springs required the hanger to be relocated I'd wonder if they are the wrong length. (like using a 56" 3/4 ton spring on a a 1/2 ton 52" spring truck)
A shackle flip does require the replacement of the spring hanger, but most use the stock holes in the frame so they are not moved.
Personally, I'm partial to the shackle flip. Ride is better and flexes better. Still got the 4" worth of lift, just with a nice, soft, flat spring. Just get a kit that has springs for the front, block in the rear. Ditch the blocks, find some decent stock 1/2 ton springs and get a flip kit. The lift kit with just front springs plus a shackle flip would be about the same cost as getting an all spring kit. The only added cost would be replacing the 6" rear springs you have now with some stock 1/2 ton rear springs.
With the pile of rigs you have, you might even have some stock springs laying around.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 12-07-2006, 08:32 PM   #3
1969k10stepside
The 6 inch lift kit on it was a block lift and if I remember correctly it had a shackle flip too.I unfortunatly with all the trucks and parts I have dont have any good springs.I didnt know the springs werent good until I removed the blocks and found a spring cracked.Here is a pic of the rear spring hanger.It isnt a great pic but all I have at the moment
Old 12-07-2006, 08:53 PM   #4
Blue_71
Bloo
Blue_71's Avatar
which truck is that on, the 71 swb?
that pic has the hanger in the stock direction, so its not a shackle flip.. it just looks to me like someone put a longer spring in... 73+ maybe?
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 12-07-2006, 08:57 PM   #5
1969k10stepside
Thats on the 71 swb.I figured it was a shackel flip because it didnt look like the ones on my 69 lwb.I will have to meausure them I guess.I need some measurements from a stock swb I guess to check the location of the stock hangers but those appear to have been moved,you can sort of see where stock location was
Old 12-07-2006, 09:00 PM   #6
Blue_71
Bloo
Blue_71's Avatar
ah gotcha. someone may correct me on this, but im 99% sure thats how they're supposed to go from the factory. but then again, mines a k20 so who knows whats different, . i would peg that as a later model spring though
Old 12-08-2006, 12:36 AM   #7
Zoomad75
K5Camper
Zoomad75's Avatar
That is most definately a stock hanger/shackle setup right there. It has been moved forward but I don't know why.
A shackle flip ends up pointing the shackle down opposite to the stock setup. Here's a pic of Sky's hanger:
Rob Z.
Old 12-08-2006, 10:32 AM   #8
Burt4x4
Burt4x4's Avatar
One thing to keep in mind when buying per-made all spring lift is most ALL pre-fabed springs are made to Pick-up weight specs..NOT Blazers. WHat that means is your 4" front and 4" rear springs will not sit level...saggy butt synrome. The rear of a Blazer is much heavier than a Pickup..especially when the hardtop is on.
I put 4" Ranchos up front with 5.5" Superlift rears and with my hard top on my K5 sat level. With the hardtop off I have a slight stinkbug look but I like that WAY better than a saggy butt....
Now that my springs have been on for several years they have 'setteled' in and even with my hardtop gone now my rig is perrty much level...ofcoarse I added more weight to the rear with my bumper and swing out tire gate.
Something to consider.....
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 12-08-2006, 10:42 AM   #9
1969k10stepside
Well,I guess I will be moving the spring hanger back to the stock location if I can figure out why it was moved.Atleast it will be easy because the hangers just bolt on.
Old 12-08-2006, 03:14 PM   #10
Burt4x4
Burt4x4's Avatar
ooopss just relized you have a pickup and not a blazer..sorry..one track mind...
Old 12-08-2006, 04:48 PM   #11
msgross
msgross's Avatar
remember that 67-68's have longer rear springs than 69 & newer. Maybe your frame isn't as new as you thought and someone moved it forward to put newer springs on it. Look at the 4x4 companies that sell springs and you can't find old 68 springs for a lift, only blocks! Here is my 68 SWB spring locations.
msgross is offline   Reply With Quote
Old 12-08-2006, 05:22 PM   #12
1969k10stepside
I will keep that in mind.I guess I need to run the VIN on the frame
Old 12-08-2006, 07:21 PM   #13
msgross
msgross's Avatar
measure your springs (eye to eye) I think the two sizes are 52" and 56" but don't quote me. My 68 has the longer ones. Take some more pics and I can compare measurements for ya.
Old 12-08-2006, 07:24 PM   #14
1969k10stepside
Well,its the original frame,the 67-70s had different front spring hangers than the 71-72 and the front ones are correct for the 71 model and are still riveted to the frame.I will get some new batteries for my camera and get out to the shop to measure the springs tomorrow when I get back from looking at two 4x4 parts trucks
Old 12-09-2006, 10:02 PM   #15
1969k10stepside
Started a thread here asking for info for anyone reading this has info and wants to reply:http://67-72chevytrucks.com/vboard/s...d.php?t=218982
Old 12-21-2006, 05:59 PM   #16
Critter
Future TOTM Winner
Critter's Avatar
From what I have seen, a rear shackle flip will cause the axel to sit farther forward due to the change in geometry. First off, am I right on that?
Second, I am dealing with a 72 k5 blazer (1/2 ton springs) which I believe came stock with the 52” spring. Can I somehow use a 56” spring to put the axel back in its correct location? I’m sure I would have to drill new holes in the rear of the frame because the shackle flip would no longer be able to use the original rivet holes. Am I making this harder than it really is?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 12-21-2006, 06:02 PM   #17
1969k10stepside
The shackel flip will move the axle forward.I dont know about using 56" springs but I am sure it can be done and probably has been done.
