Old 12-07-2006, 09:15 PM   #1
Boise69
The Hammer Man
Boise69's Avatar
Bench seat
Can you make a stock bench seat recline forward? Or do you have to get a new seat if you want that feature?
Boise69. Bought in Boise ID and its a '69
___________________________________________
1969 Chevy C-10 SWB 350/400 - drivable project
www.americanhammer.com
2013 MBZ Sprinter customized
2005 MBZ Sprinter Van
2004 Land Rover Discovery
2001 Yamaha Road Star
1997 MBZ E420
1989 Ferrari Mondial T
Boise69 is offline   Reply With Quote
Old 12-07-2006, 09:55 PM   #2
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
Re: Bench seat
I'd be interesred in finding out also. Anyone convert the non-folding to a folding?
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 12-07-2006, 09:58 PM   #3
BarryB
BarryB's Avatar
Re: Bench seat
I have not done this particular convert myself. but being an Upholsterer myself. You can do this but it would involve doing some redoing of your seatframe. and your covers. It might be cheaper to find a newer seat and have it covered to match your truck.
BarryB is offline   Reply With Quote
Old 12-07-2006, 09:58 PM   #4
msgross
msgross's Avatar
Re: Bench seat
I think that mine just has a wingnut holding it "up" so i can remove it and recline forward.
msgross is offline   Reply With Quote
Old 12-08-2006, 01:29 AM   #5
myoldchev
Junior Member
myoldchev's Avatar
Re: Bench seat
Mine folds forward 7 or 8 inches. It had 2 bolts in each side. I just removed the back bolt on either side and now I can get behind it.
DAN
69 CUSTOM 10 LWB:
myoldchev is offline   Reply With Quote
Old 12-08-2006, 01:56 AM   #6
Draggn66
Draggn66's Avatar
Re: Bench seat
I wondered if it was just that easy? Anyone else?
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
Old 12-08-2006, 07:43 AM   #7
Re: Bench seat
When I had one,that is how I did mine. Just take the one screw/bolt on on each side and you are in business.
Old 12-08-2006, 09:09 AM   #8
QKENUF4U
QKENUF4U's Avatar
Re: Bench seat
if ya remove that bolt what keeps it from crushing you in an accident ?? im guessing your only removeing the bolt long enough to pull it forward then putting the bolt back right ?
QKENUF4U is offline   Reply With Quote
Old 12-08-2006, 09:10 AM   #9
Draggn66
Draggn66's Avatar
Re: Bench seat
How does that effect the "dog ears" from the top seat cover? Can they still be attached as before or will it pull them loose when you fold the seat forward?
Hey Ted.....not tryin to take over your thread......just very interested!
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
Old 12-08-2006, 09:13 AM   #10
msgross
msgross's Avatar
Re: Bench seat
YOUR SEATBELT! If you are in an accident and your seat "crushes" you I can't see that little bolt stopping anything. Hopefully you gas tank is secured...
Old 12-08-2006, 12:06 PM   #11
70c10
67-72 Addict!
70c10's Avatar
Re: Bench seat
My stock bench flips forward with a lever on the rear. I heard this was only available on some 67' trucks. It was in my truck when I bought it.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-08-2006, 01:19 PM   #12
Re: Bench seat
The seatbelt!
Old 12-08-2006, 01:23 PM   #13
Boise69
The Hammer Man
Boise69's Avatar
Re: Bench seat
No problem Randy, you are welcome to it, i'll be looking at that bolt a little later today. If i'm going to be putting my amps and subs back there i want access to it when i want and if all it takes it to remove two bolts then very cool, but if you take those bolts out, will the seat bang when you hits bumps i wonder?
1997 MBZ E420
Old 12-08-2006, 02:20 PM   #14
myoldchev
Junior Member
myoldchev's Avatar
Re: Bench seat
I've never had a problem with it folding forward at the wrong time. Just make sure everything is tied down really well behind it.
DAN
69 CUSTOM 10 LWB:
Old 12-08-2006, 03:55 PM   #15
Draggn66
Draggn66's Avatar
Re: Bench seat
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
Old 12-08-2006, 04:51 PM   #16
shifty
Questionable
shifty's Avatar
Re: Bench seat
My stock bench already folded forward when I bought the truck...
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
