flasher switch
So when I was testing out my flashers to see if they worked (they did), the button got stuck down. Then, trying to pull the button back out, my nice, original flasher button decided that 37 years was a long enough life. Now my flashers on constantly on. How can I turn them back off without the button? I couldn't see anything to pull out. Well, except for the relay at the fuse box. Thanks.
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
Re: flasher switch
Is there still a stub in there? if so get a small screw or go to a pull a part and get a newer knob that screws in and install it. If this doesnt work you are going to have to remove the steering wheel and replace the switch if it is a non tilt colum. If it is a tilt coulum it uses a seperarte screw on knob. Sorry.
Re: flasher switch
On this subject, who sells a new switch????
Re: flasher switch
Yeah, I've been w/o flasher button since I got this truck. My daughter decided to pull out the "cute little orange thing"... Any way, atleast the flashers were off...
its all about the +6 inches
Re: flasher switch
simply pulling the flasher out will get the job done, but your front markers will come on when you hit the brakes, and I don't think the turn signals will work when you hit the brakes either.
You can reach in there with some real small needle nose pliers and pull on the nub, that should turn them off.... DISCONNECT THE BATTERY before doing this... otherwise, you'll short to ground and blow your fuse. |
Re: flasher switch
yeah, already blew that fuse. oops. at least i didn't melt any wires. none, that i know of, that is.
Re: flasher switch
I am still looking to replace mine.
Re: flasher switch
you'll have to replace the entire turn signal switch... any parts house or dealership. Before walking out with the part, make sure the adapter is in the box, if not, get one under GM P/N1894851.
Re: flasher switch
Try this link www.truckandcarshop.com just replaced mine and it wasn't to bad. Just have to pull the steering wheel to get at the switch.
Re: flasher switch
Try the local parts store for a new turn signal switch and flasher, whole assembally. I know oreillys carrys them, my friend got one there a couple years back for a 68 straight colum. Hope this helps.
New Member
![]() Join Date: Jun 2006
Re: flasher switch
I would highly recommend AC/Delco when you replace it, some of the other after market switches are pretty weak.
![]() Join Date: Sep 2005
Re: flasher switch
http://www.manestruckparts.com/store...&Category_ID=8
34 buxs it even look oringal i got mine for advance auto parts and it has the newer black push and pull button
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#13 |
Re: flasher switch
The one avaliable at oreillys is the delco one, havent ever used an aftermarket one.
David, I also like the new replacement ones, I like the new style flasher button, works alot better and looks alot better to me than the old ones. Last edited by Aarons72s; 12-12-2006 at 10:37 PM. |
#14 |
I get it I get it I get it!!! It is part of the turn signal mechanism!!! Thank you all so much!!!
#15 |
Re: flasher switch
yw i like the newer one my self easlier to use plus if it breaks its easy to replace
