Old 12-08-2006, 08:17 PM   #1
mySAVIOReigns
Active Member
mySAVIOReigns's Avatar
Leak - need help
Went out to my truck after work and saw some fluids under the truck. Uh oh...
So I rub my hand in it, and it's gas. Now the question is, it's under the engine bay. So where could this be coming from? I'm not very knowledgeable when it comes to fuel and stuff, so if you can detail your response, I appreciate it Thanks
Website Here
-Stephen
1985 Chevy Silverado, 1/2 ton
mySAVIOReigns is offline   Reply With Quote
Old 12-08-2006, 08:34 PM   #2
magnethead
7000 #'s of american IRON
magnethead's Avatar
Re: Leak - need help
fuel pump, cracked fuel line, loose hard to rubberline fitting...
all i can think of, anywhere else would drip on the intake.
magnethead is offline   Reply With Quote
Old 12-08-2006, 08:40 PM   #3
mySAVIOReigns
Active Member
Thanks, I'll give that a look tomorrow
Website Here
-Stephen
Old 12-08-2006, 08:52 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
I had a fuel line crack right at the frame by the motor on the passenger side of my 84, yeasr ago. It was on the return line and was spraying on the exhaust pipe, when I found it. SO watch out for what could be a fire hazard.
piecesparts is offline   Reply With Quote
