12-09-2006, 09:47 AM | #1 |
Crew Cut
crew cab headliner board ?
where can i buy a headliner board for a 88 crew cab. i am building a swb half ton crew cab
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
12-10-2006, 07:23 PM | #2 |
67-72 parts collector,…
Re: crew cab headliner board ?
Try cheyenne pickup parts. I think they have a repop one. Check the link,... and post some pics of your project! I want to do the same with my '89 1 ton crew. http://www.cheyennepickup.com/
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-16-2006 at 09:19 PM. |
12-16-2006, 05:18 PM | #3 |
Count me in as someone that wants pictures of a swb crew cab.
I'm on my way to look at a '86 long bed crew and I want to make it a short bed. |
12-17-2006, 08:40 AM | #4 |
Crew Cut
ok here we go. about 2 weeks ago i put a crew cab swb together started off w/ a 1 ton dulley and a swb 1/2 ton. i got the frames put together w/ the swb bed bolted on and the 1/2 ton front suspension bolted in place. i now have the truck rolling as 1 unit but it now needs inside, engine and trans.
this is the good part.when we went to lunch the same day we got finished with all of this we passed a car lot and there sat a 88 crew cab big block dulley and i know the owner that bought it new. i made a offer and i now have the new truck at home. i also have another doner 1/2 ton, already have it taken apart am going to steam clean the frame today and may get to cut the frame and get front suspension out. will get some pics in a few days
12-17-2006, 09:27 AM | #5 |
Can't wait to see pics.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-17-2006, 12:49 PM | #6 | |
So wait, you have one done as a roller and now your going to start in on another one? You sound like me...
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
12-17-2006, 03:03 PM | #7 | |
pictures, pictures, pictures please. Hey OJOE do you have pictures of youre frame, where you cut it, how you boxed it, how bed mounts lined up. etc. etc. pictures work better for me, words seem to get mixed up with all the crazy voices in my head |
12-17-2006, 07:24 PM | #8 |
Add me to the list of people waiting for pics! OJOE, what are you doing in for the rear suspension? Will the 1/2 ton leaf springs swap directly into the 1-ton hangers? Also,... Is there a difference with the shock mounts? Keep us posted!
12-17-2006, 07:59 PM | #9 | |
Crew Cut
the rear cab mounts will be the center of the frame repair. also the 1 ton frame is about 1 1/2" taller than the 1/2 ton frame. now for the 1/2 ton, remove the cab and bed. cut the frame about 10 or 12 inches in front of the rear cab mounts, then remove the rivets on rear cab mounts, in order to slide therear frame into the front frame you will need to cut off the top lip of the 1/2 ton frame just to where it over laps so the top of the 2 frames will be even. now the easy part just slide the rear frame into the front frame. slide it in until the cab mount holes in the 2 frames line up you will also see that all of the other holes including gas tank mounting holes will line up you can get 12 bolts on each side in factory holes. bolt on the cab mounts thru the 2 frames and the cab mounts. and weld as moch as you want. then you can bolt on the short bed in the factory holes. the 2 front bed bolts will go in the 1 ton part of the frame and the other 6 will go in the 1/2 ton part of the frame and you are ready to put your 1/2 ton suspension on the front. this may not be the best way but there is no better way to keep the frame square and in line. good luck
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK Last edited by OJOE; 12-30-2007 at 03:59 AM. Reason: new info |
12-18-2006, 11:20 PM | #10 |
Thanks for the info OJOE. I just picked up a crew cab yesterday. I'm in no hurry to shortin it yet I will wait for a good deal on a short bed to fall my way.
For the mean time I'll probably make it run nice and let the wife get hay with it. Here is the picture the seller had of the truck. |
12-19-2006, 06:39 AM | #11 |
69fatmotor
here's a few pics of OJOE's first crewcab project . joe has some pics of this project from the start, but here's a couple that i took yesterday.
12-19-2006, 10:15 AM | #12 |
thanks for the pics mike.
12-19-2006, 07:32 PM | #13 |
I guess I need a donor truck!
12-20-2006, 05:24 PM | #14 |
Make mine a 4x4* please!
I would love to 1/2-ton cew 4x4 short bed. I had a '98 (3/4 ton) until last summer. It was about perfect but I didn't want the payment and gas was killing me. HUGE mistake - you live and you learn.... right?!? The argument I have heard is that you can't haul anything with a 1/2 ton but I am not looking for a hauler, just something like a Suburban, but with a bed. Besides, I had 12-14 people in my Suburban pulling my custom made bike trailer with 12-14 bikes up the hills where we rode. The trailer weighed just under 1500lbs. With each bike weighing close to 50lbs and figuring each person averaging about 175 I guess we were pulling close to 5000lbs. The Suburban didn't blink even going up some pretty steep grades on the forrest roads. (*I have nothing against 2wd's as evidenced by all the trucks in my signature being 2wd except one. Just that after driving a 2wd Suburban around I was shocked at how bad the turning radius was compared to my 4x4 Suburban.)
12-20-2006, 05:26 PM | #15 | |
So did you use the short bed tanks or the long bed tanks?
12-20-2006, 07:44 PM | #16 |
12-20-2006, 08:59 PM | #17 | |
Also, 1/2 ton parts would be cheaper, more interchangability with parts and most importantly, I think a 1/2 ton would ride a little better. I would sacrifice my '86 GMC 4x4 towards something like this if I could find a crewcab 4x4 for the right price. This would give a rebuilt 350 & 700r4, 3.73 axles now with all new front suspension, brakes and an Eaton posi from the parts truck, real nice interior (at least the front), and nice body parts. Actually, my parts '85 swb has a good bed on it and the frame is bent up on the frame horns and just under the engine so I guess I already have half the project in my driveway...
12-20-2006, 09:10 PM | #18 |
12-21-2006, 09:38 PM | #19 |
Crew Cut
you will not be able to use long bed tanks,to long. the short bed tanks will bolt in. i am going to use a fuel tank in the bed (25-35gal) under my gaylords cover. some may not like it,just my choice.
12-25-2006, 06:30 PM | #20 |
Since this has sorta became the "unofficial" crewcab shortbed thread, I thought I would put a link to my photoshop page of my crewcab.
If any of you guys have ideas on what you would like to see done to it just ask and I will try. Also if you would like youre own crewcab photoshoped let me know maybe I can help. |
04-09-2007, 01:03 PM | #21 |
Here's pictures of the second Crewcab Shortbed we worked on this weekend.
04-10-2007, 09:17 PM | #22 |
Luv the Crewcabs
Thanks for all the Tip's on how to do this, Will add to my want to do list of Projects............
Thanks, Rick |
01-27-2008, 11:17 AM | #23 |
Proud Father
I can get a swb truck that's trashed in the front for $200.00 for a donor, now all I need is a crewcab. Thanks for the info and pics guys. Just let me verify this again the rear cab mounts will line up right? Are they pretty safe bolted up like this? or should a person weld it up just to be a little safer?
1969 Chevy C/10 "My dad's, May he rest in peace" 1988 GMC Suburban 1/2 ton 2wd 1952 Ford F-600 1989 Toyota P/U "The Beater" Last edited by Joes69c10; 01-27-2008 at 11:18 AM. Reason: Fingers to fat for typing!!! |
01-27-2008, 11:45 AM | #24 |
Like in other posts,... the bolts are just for "alignment purposes". Complete "quality" welding needs to be done to the frames.
01-27-2008, 11:54 AM | #25 |
Proud Father
Sorry to be a pest. Read everything again and seen all the info. I need new glasses so i accidentally skipped it somewhere. Thanks JOE
1969 Chevy C/10 "My dad's, May he rest in peace" 1988 GMC Suburban 1/2 ton 2wd 1952 Ford F-600 1989 Toyota P/U "The Beater" |
