Old 12-09-2006, 01:04 PM   #1
Fastfun
Fastfun's Avatar
one piece windows
I am planning on purchasing the one piece windows and I have a question to anybody that has installed them. I can not decide if I want to go with the clear and have them tinted or if the gray would be dark enough. I know Brothers sells them, is there anybody else that sells them cheaper.
Fastfun is offline   Reply With Quote
Old 12-09-2006, 01:06 PM   #2
John Fabris
TOTY 2006
John Fabris's Avatar
Re: one piece windows
Since you are in AZ, order the ones that are already tinted. Check with any of the board venders here for the windows, but I think those get them from brother as well. Someone will correct me if I am wrong...
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 12-09-2006, 01:13 PM   #3
kyull67
kyull67's Avatar
I bought the tinted version from brothers and they are not very dark. Great product though. I waited for them to go on sale, but if you factor in the time and money spent repairing the vent windows it's money well spent. Plus I think they look better.
kyull67 is offline   Reply With Quote
Old 12-09-2006, 01:17 PM   #4
brak
brak's Avatar
why don't you just buy the clear, and tint them the shade you want?
Since the windows will be out of the vehicle, it would be very easy, and only take maybe an hour.
just my opinion
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 12-09-2006, 01:23 PM   #5
kyull67
kyull67's Avatar
Old 12-09-2006, 03:07 PM   #6
nandress
nandress's Avatar
The tint is about 35%, but is not super dark. If you doubt it will do for AZ, then buy the clear and tint them (I actually think the clear are a little easier to get, as my tinted ones were backordered when I bought them).
<<EDIT>> If your avatar photo is accurate, that is just about the tint that the tinted kit is.
Brothers makes this kit, so you will not find it cheaper with anyone else.
From my experience, there was some trouble with the door check modification. I suspect it is because the early 67's had a slightly different check design, but we had to pretty extensively modify our checks, including springs and stuff, to get them to work. When I called Brothers on this, they had not heard of anyone having trouble.
nandress is offline   Reply With Quote
Old 12-09-2006, 03:34 PM   #7
b&a72
Active Member
b&a72's Avatar
nandress are the directions pretty easy to follow?
b&a72 is offline   Reply With Quote
Old 12-09-2006, 04:25 PM   #8
nandress
nandress's Avatar
For the most part, yes! It's been a while, so I am not able to remember if there was anything specifically wrong with the instructions. I know it was only a couple hours, and once you had one done the other was simple.
But there were a few hiccups that were caused by minor details on our truck that Brothers couldn't have forseen that we had to deal with, the door check being the most frustrating.
Old 12-09-2006, 05:42 PM   #9
John Fabris
TOTY 2006
I agree with nandress, pretty simple to follow, and even if you are using new door hinges, I would still modify the door checks as described in the directions.
If you are doing this for the first time, try to get someone else that has done this before to give you a hand. For me, I took my time doing it, and I was a little apprehensive, but now that I did one, I would no problems doing it again.
John Fabris
67 C10 SWB
Old 12-10-2006, 12:19 AM   #10
Slammed70
Slammed70's Avatar
Dont forget to weld up the holes where the wing window screws went.
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 12-10-2006, 12:26 AM   #11
chevyboy55
chevyboy55's Avatar
I think chevydude did a install thread on his windows.He had lots of pics & good detailed directions.We put a set in my sons 72 & they were very easy to install.Brothers was a real big help when I had a question. Good luck!
chevyboy55 is offline   Reply With Quote
Old 12-10-2006, 12:30 AM   #12
kyull67
kyull67's Avatar
I've got a '67 and as long as you cut down the door checks as described in the directions there are no problems at all. Pretty easy install, can be done in about 2-3 hours.
Old 12-10-2006, 02:48 AM   #13
nandress
nandress's Avatar
There wasn't really a problem with the ground down shape...Once it was trimmed up, it would clear easy. Our problem was the result of the tightness of the door checks in the hinge slides. It would hold the check out so that no matter what you did it would hit the front track when you shut the door. We had to make a spring bracket to tug the check out of the way when the door was closed.
Hind sight would have said to just buy new hinges. Like I said, even Brothers had never heard of anyone else having the same problem!!
Old 12-10-2006, 12:05 PM   #14
John Fabris
TOTY 2006
What I did on the door check with my truck after grinding them down to the reccommended shape, was to add rubber coated washers that I cut a slot in and then using a hammer and punch, inserted them around the spring pin between the check and door hinges. This got rid of the sloppiness of the door check which is what the issue is.
John Fabris
67 C10 SWB
Old 12-10-2006, 04:01 PM   #15
Fastfun
Fastfun's Avatar
Thanks everybody for the response. I will be ordering the one piece window on Monday and I will go with the clear glass and tint to the darkness that I want.
Prices I found
Brothers 359.96
Classic Parts Depot 339.00
Mother Truckers 329.00
Old 12-10-2006, 04:55 PM   #16
CMars45000
CMars45000's Avatar
a little aside on this subject: Will the standard 1-piece window kit that brothers sell (the one for manual crank windows) work with existing power window regulators? or so I have to but the entire power 1-piece window kit to go that route?
thanks
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 12-10-2006, 04:57 PM   #17
bowtiehotrodder
SIX BANGER
bowtiehotrodder's Avatar
i help a friend do them it was really simple
http://www.cardomain.com/ride/2597018(NN)
1979 chevy truck swb 454 w turbo400 with buckets
1977 chevy truck swb soon to be 454
1976 chevy dually 454
1969 chevy truck six shooter
bowtiehotrodder is offline   Reply With Quote
Old 12-11-2006, 10:48 AM   #18
rodstored-72
chevy truck fan
rodstored-72's Avatar
fastfun,
i would like to see how that turns out & if you want or would need some help & cant' get a extra pair of hands give me a shout (pm) & i will come over. hey did you get the vette fixed in time for the goodguys show?? i went & it was a blast although i have a little problem with the frontend on my truck, it is still very drivable though. i hope things are going good for you...
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 12-11-2006, 03:06 PM   #19
Lemield
Lemield's Avatar
Cmars45000,
Send a PM to Chevydude. He can probably answer the question since he has electric in his truck. Mine are manual with the light tint...nice windows.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 12-11-2006, 04:22 PM   #20
John @ BROTHERS
John @ BROTHERS's Avatar
Window kits are on sale today - Check out the Calender
Non power - $325.00
Power - $675.00
1967 Chevy Short/Fleet
1969 Chevy Short/Step
2004.5 Dodge 2500 4x4 Cummins 6spd
John @ BROTHERS is offline   Reply With Quote
Old 12-13-2006, 12:18 AM   #21
Fastfun
Fastfun's Avatar
Ordered the windows today from Brothers and they are on backorder until after Xmas
Old 11-02-2007, 12:11 AM   #22
pissonNOS
senior member
pissonNOS's Avatar
I know im bringing this back from the dead but I was going to order the one piece kit tomorrow I hope and thought some one else might want to know there on sale now $299 and if ur a canadian thats only$285 woo! anyways I found this thred because I was looking for feed back ont he windows looks good to me
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 11-02-2007, 01:01 AM   #23
Mondo
Mondo's Avatar
These cost more but don't have that little triangle metal piece at front of window...
http://www.onepieceproducts.com/Prod...ductid=OPP6772
Mondo is offline   Reply With Quote
