Old 08-19-2002, 11:40 PM   #1
chevy garage
chevy garage's Avatar
Question tire / wheel sizes
I'm planning to run 15x10's on rear of 70 swb with 285/70/15's. Will I have any clearance problems with a 2/4 drop?
Thanks.
chevy garage is offline   Reply With Quote
Old 08-20-2002, 01:17 AM   #2
Craig Wick
15x10 with 5 inch back spacing will fit.
Craig Wick is offline   Reply With Quote
Old 08-20-2002, 10:45 PM   #3
chevy garage
Thanks for the info. I didn't want to get into trouble.
Old 08-20-2002, 11:12 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
While I don't know the backspacing on my rims (they were there when i bought it) I can say that 275/60R15's fit with plenty of room on the sides, even when I had it loaded down and sagging about 5 inches. (fleet bed)
Old 08-20-2002, 11:22 PM   #5
chevy garage
I just bought an old set of 200S American's. I think the backspace is 3 1/4. But I'm not sure. I bought 2 10's & 2 8.5's. I may have some problems. I'm getting the axles redrilled, so I'll have to wait and see.
Old 08-20-2002, 11:27 PM   #6
Benrs86
Benrs86's Avatar
your cool with 3.25 and fleetside. im running 15 by 10s with 3.25" backspacing and 295/50s all around. TONS of room everywhere. the only semi-close spot is in the rear, the tires are close to the inside of the wheel well, but id say it still has 1, maybe 1.25" inches to spare. mine is stock hight tho, im planning to drop the front a coils height im broke, if it dont work, ill get new springs. so i dont think anything bad could happen. hey, it will be a learning experience at the least. good luck man, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 08-20-2002, 11:38 PM   #7
chevy garage
Those 295's are about 10.5 or 11 inches wide aren't they?
I should be in good shape.
Old 08-20-2002, 11:44 PM   #8
Benrs86
Benrs86's Avatar
at the widest point in the bulge they are about 12.5" . they are the multi mile tire. dang, cant think of the name, but they are made my multi mile. heres a pic, but its a side shot
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
Old 08-21-2002, 09:01 PM   #9
chevy garage
Smile
Thanks for the picture. You've got a nice truck. That helped me out.
Old 08-23-2002, 05:26 AM   #10
The Blue Pig
Thread Wizard Since 2002
Hey Benrs86, I just wanted to let you know that your rear marker lens on your drivers side fell off. You can thank me later.
--70 C-10 Longbed
--71 C-10 Longbed
--72 K-20 Longbed
--74 C-10 Shortbed
--86 Toyota Tercel (His Driver)
--05 Chevy Trailblazer (Her Driver)
The Blue Pig is offline   Reply With Quote
