Dave's not here, man
Pitman Arm Question
I was planning on swapping the suspension from a 79 parts truck to my 68 so I'll have discs. My question is will the pitman arm from the 79 work with the steering box on my 68?
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Re: Pitman Arm Question
does your 68 have PS? If not then swap the entire box, I am...
It has manual steering. The only problem with swapping the box is that I sold all the AC components off the truck and it looked as though the AC compressor shared a bracket with the PS reservoir. This was the post I read that made me think I couldn't use the box from the '79.
"there is also a difference in the 77-up boxes the steering shaft coming out of the box that hooks to the column get smaller in the 77 up boxes so it will not bolt to your stock steering column (CableGuy0)"
ttt
Sorry not sure on the pitman arm if you are using the 79 center link and tie rods. But get the rag joint for a 77-84 truck. It will bolt to the steering box and your colum. Hope this helps.
I did this conversion on my 67 a few years ago. When i went to install the steering box it hit the frame before it could be tightened up. I had to cut a section out and weld in a piece I cut out of the donor truck. Just the part with the reliefe. It took a Sat afternoon to do it. I belive they make a bolt in kit for it too.
Forgot to mention someone told me that someone may have swapped the frame on my truck to a 66.
![]() Join Date: Aug 2004
You could run the later box and loop the hydraulic lines untill you can come up with a pump. I did that for about a year on my previous 68. It wasn't any harder to steer than the manual box. Just use the later rag joint and it should bolt in.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Thanks for all the replies. I'll keep you posted on my findings.
