Roadtrip!
![]() Join Date: Feb 2003
Another FYI: Choke deletes
Since people liked the FYI: tow hook thread, lets throw some choke deletes in the mix. I have managed to find 4 different styles. I believe these were used on 67 trucks equipped with a 327 and Q-jet carbs and 68 trucks with a 327 or 396 with a Q-jet. Please correct me if i am wrong. The 2 gm ones share the same part number and national detroit on the back. Only difference i can see is the square and round corners. The 2 round ones are chrome and wrinkle finish. Maybe a cst thing? I threw in a pic of a choke plate and a dash bezel that didn't come with a choke stamp on it. Enjoy... Add coments or info!
Eric Not sure what FYI i can come up with next week!
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: Another FYI: Choke deletes
I have found many more square ones than the other style. Also have found quite a few of the plastic "CHOKE" tabs while looking for the "THROTTLE" tabs.
The rare tab is the "REAR A/C" for the Suburbans.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Roadtrip!
Bob, i included a couple pics so people understand what you are referring to. Was that rear a/c tab different for the earlier years? This one is on my 72.
And thanks Aaron for the last delete!!
Great thread too much stuff. Glad I was able to supply the last delete for you. I wander if there are any more different ones out there?
Several years ago(more like 10 now) when I first started fooling with trucks the only place I was familiar with to get parts was Golden State Pickup Parts in so-cal. Their catalog listed a THROTTLE name plate whick I wanted as I had the factory hand throttle. I ordered one and it was backordered. I called several times and was always told on backorder. I finally asked for my money back and was told everytime they removed one it would break. Finally I did receive it in the mail. Turned out to be a strip like the ACC/OFF/IGN used on the 71-72 trucks. I later found what they sent me came from an early van. About 2 years later a very nice fellow who ran a local junkyard told me to look in an old air force surplus truck in his yard and lo and behold there was the proper THROTTLE tab. No charge he said. I really miss him and his yard.
My Suburban has rear A/C and it doesn't have that plate on the dash, what does that one do? Control the blower motor speed?
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
Here is my choke delete, I also have a throttle tab, truck is a 68 K-10 327cid and had a divorced choke before I changed to a newer intake. I would like to find a nicer one for my bezel though!
I have seen some Suburbans with the A/C down the center roof from front to back. Those have a knob above the drivers right shoulder on the unit itself to control the blower speed.
You can find the rear A/C blower switches in conversion vans up to 88 or so. The 73+ suburbans with rear air use a rocker type switch while the vans use a twist type that accept the 67-72 style knobs. This thread has changed has from choke deletes to general cluster data.
Questionable
Is it still possible to buy one of these online or otherwise? What do prices normally run? Would be cool to pick one up, I will need to use one with my truck after the swap, but it would only be there till I mod a glovebox door to house my gauges instead.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
I haven't seen choke deletes in a mag yet. I did see one on Ebay and I remember it being a little pricey $30+ maybe but that would make since now seeing as I haven't seen any more since then.
I am surprised the first 2 havent been reproduced yet. Ok aftermarket parts suppliers do you hear us.
SWB 4X4 CLUB
I have one I am going to try to repaint somehow. It is the one that is square Like in the above picture.
If anybody is interestedin one check out the following link. scroll down toward the bottom of the page. http://www.americanclassic.com/asp/d...to&exyear=1972 Jason |
#13 |
and there it is...not worth $35 for me right now though...little elbow grease and some paint maybe....
#14 |
I have one of the square-cornered ones. It came off a '68 'Burb with a 327.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
