Old 12-10-2006, 06:05 PM   #1
gouldie
another tail light question
a few weeks ago i posted about my taillights not working. the suggestion was the headlight switch or the fuse. i replaced both and now only have 1 brake light working.
at the wire connection on the rear crossmember i got 12 volts for 1 of the 4 wires, makes sense. i then moved up to the conection on the firewall to test those for power. 3 of them had 12 volts, the light green had 0 volts.
my only guess is the connector is no working, cutting the power to 2 of the wires. none of the wires are cut.
any ideas what could be the proble for the 2 wires not working and the lack of power to the light green.
67 c10 250 I6 3 on the tree no options
air ride, paint and big block coming within the next 23 years
2001 mustang gt for going fast
gouldie is offline   Reply With Quote
Old 12-10-2006, 06:43 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: another tail light question
you had power on 3 terminals...was that with the parking lights on, and the brake lights on too? If so, then you are OK up to that point.
