Old 12-10-2006, 07:04 PM   #1
mtm_seven
Loading.....
mtm_seven's Avatar
Buy c-notch or make my own?
Hey Guys,
I'm looking into notching the rear of my '67 for bags and wonder if it's worth paying for the kit or just fabbing some for myself.
Anyone made their own C-Notch kit? Horror stories? Maybe I'm just a cheep MoFo but I wonder if I could spend that money someplace else.
Comments?
-M7
'69 SWB GMC 5.7 EFI
‘69 C/10 SWB patina survivor
‘71 K20 LWB GMC
'72 K5 1-ton gear 468BB
‘79 K20 LWB GMC
‘86 K30 GMC High Sierra C&C Single Cab
‘94 LWB GMC 2500 4x4
'96 SWB Single Cab 5.7
‘99 SWB Z71 Single Cab
'01 K2500 Yukon Safari 6.0
‘06 1500 LWB 4x4 5.3
‘06 2500HD Single Cab C&C Duramax 4x4
'08 2500HD x-cab duramax 4x4
'11 2500HD Single Cab Duramax 4x4
mtm_seven is offline   Reply With Quote
Old 12-10-2006, 08:55 PM   #2
action
Active Member
action's Avatar
Re: Buy c-notch or make my own?
I don't know about anyone else but I am going to fab my own.
Jack
action is offline   Reply With Quote
Old 12-10-2006, 09:30 PM   #3
BigShoe24
True Addiction
BigShoe24's Avatar
KpComponents makes a great kit. Its a little $$$$, but looks great.
BigShoe24 is offline   Reply With Quote
Old 12-10-2006, 09:55 PM   #4
jimmydean
jimmydean's Avatar
I have seen pictures of some solid ones around here. Just get 1/4" thick 4" or so pipe, cut it in half, and weld it in.
I got the CPP bolt-in notch because I want mine as beefy as possible. I will weld it in once it's bolted to make it better than stock.
jimmydean is offline   Reply With Quote
Old 12-10-2006, 10:05 PM   #5
jlaird
jlaird's Avatar
My vote is to make it yourself!
jlaird is offline   Reply With Quote
Old 12-10-2006, 11:01 PM   #6
action
Active Member
action's Avatar
I am going to do just what jimmydean said but was thinking 5".Add a little
1/4" plate and done.
Jack
Old 12-10-2006, 11:28 PM   #7
jimmydean
jimmydean's Avatar
Sounds like a plan. 4" was a guess, I would think 5" or so would work.
Old 12-10-2006, 11:45 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
You doing a C-notch or a step notch? If your just doing a C-notch then the pipe will work just fine. Just be sure to box the inside of the frame too...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-11-2006, 12:30 AM   #9
el curioso
el curioso's Avatar
If you know how to weld and know how to fab go head and do it It might be the swame as the one that you will buy but you have the admiration and pride of saying i made it all work from stock.
MY two cents..
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 12-11-2006, 01:21 AM   #10
abadsvt
abadsvt's Avatar
I think you should try and make it yourself. It is amazing what you can accomplish by trying it your self. Good luck and post pics when you are done.
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 12-11-2006, 03:12 AM   #11
gringoloco
A guy with a truck
gringoloco's Avatar
CPP notch is nice though, and only $100. Takes all the guesswork out of it though- some of the fun too...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-11-2006, 11:49 AM   #12
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
I would agree that the pre-fab notch kits are a good way to go. Depends what you consider your time is worth. Spending $100 might save you a lot of time in the end.
I am in the process of cutting out my custom-built c-notch and installing a pre-fab one. We "guessed" a little incorrectly on the pipe diameter and placement of the notch. If you consider doing things twice as being fun, I guess I'm having a blast.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 12-11-2006, 12:13 PM   #13
Shane
Shane's Avatar
Buy it, it's definitely worth the price vs. the time invested in doing it yourself.
Shane is offline   Reply With Quote
Old 12-11-2006, 06:32 PM   #14
entourageguy
Yellow truck club
entourageguy's Avatar
Hey Big Shoe
I'm not trying to be nosey but by the pic it looks like the notches have not been put in the same way..
Brian
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 12-11-2006, 09:30 PM   #15
ctg611
ctg611's Avatar
Here are the C notch's I did on my 66 GMC. Took pipe, cut in half, cut frame, placed in pipe and then boxed in the frame.
ctg611 is offline   Reply With Quote
Old 12-11-2006, 10:15 PM   #16
mtm_seven
Loading.....
mtm_seven's Avatar
Thanks for the replies guys, keep 'em coming.
With the pipe method, how low can you get the truck? I'm not looking to scrape the ground but want to be able to match whatever front height that I use.
The plan as of now is 2.5 drop spindles and cut one loop from the spring in the front with bags and a c-notch in the rear. Does anyone think I'll have trouble getting low enuff in the back?
-M7
'69 SWB GMC 5.7 EFI
‘71 K20 LWB GMC
‘79 K20 LWB GMC
Old 12-11-2006, 10:22 PM   #17
mtm_seven
Loading.....
mtm_seven's Avatar
Please take the time to read the rules before posting here-
XI. All For Sale posts shall have a price or prices, as well as your
location. No bids or auctions allowed here!!! If you don't know the
price of what you are selling, then you should do some research. If a Moderator or Administrator here asks you to post price(s) and you have not within a 12 hour time frame, they will delete your thread, period.
XIV. As of October 15th 2005 subscribing members will be the only ones permitted to post for sale and want to buy ads on any classified section of this site. All other rules of buying and selling still apply. 67-72chevytrucks.com, its administrators or staff are not responsible for any transactions on or off the forums. We will work hard to ensure you a smooth transaction, and help in the event you may need it, but all for sale and trade areas are buyer beware. Any persons who have misrepresented an item, lie about an item, fail to deliver, or are in violation of any of the rules will forfeit there subscription fees and be banned from 67-72chevytrucks.com
The Forum staff would like to encourage you to become a subscribing member. Your support will be greatly appreciated.
-M7
'69 SWB GMC 5.7 EFI
‘71 K20 LWB GMC
‘79 K20 LWB GMC
Old 12-11-2006, 11:13 PM   #18
gringoloco
A guy with a truck
gringoloco's Avatar
Nope. Should be perfect. You will need the notch. -Chris
-Chris
Old 12-12-2006, 09:23 AM   #19
Inthuwind
Straight jacket required
Inthuwind's Avatar
I too have the pipe C notch with a bump stop. It's pretty low IMO. Cheaper route without sacrificing durability. I have to box mine in still. Not hard to do, just be accurate with your measuring and cutting.
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 12-13-2006, 03:48 PM   #20
laidout69
laidout69's Avatar
i say make it your self. i made my own. thats wut called custom haha
1969 chevy
bagged, fully shaved still UnDeRcOnStRuCtIoN
laidout69 is offline   Reply With Quote
Old 12-13-2006, 10:19 PM   #21
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Originally Posted by entourageguy View Post
Hey Big Shoe
Brian
It's an optical illusion that they look that way due to the angle of the notches, as they follow the natural contours of the frame. It plays tricks on your eyes.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 12-14-2006, 01:18 PM   #22
KAILUAZ
King of Rust
KAILUAZ's Avatar
I don't see how that could be, looks like the pass side is backwards.
1970 GMC 2500, 350, TH400, front disks, thats it!
My Pics
KAILUAZ is offline   Reply With Quote
Old 12-14-2006, 02:04 PM   #23
Alvin
Never Done?
Alvin's Avatar
Looks fine to me. But that is the reason I don't like step notches on these trucks. If I were interested in going that low, I'd back-half it.
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 12-14-2006, 05:28 PM   #24
XXL
Seρor Member
XXL's Avatar
This is the same truck...
XXL is offline   Reply With Quote
