Old 12-10-2006, 08:06 PM   #1
arkracing
Weekend Warrior
Exclamation WTB - ASAP = Rear End Yoke for a '71 K-10 (4x4 1/2t)
I need a rear end yoke for a '71 K-10 (I'm assuming this is the 12bolt axle? - it is stock - don't know if 2wd's are the same or not..maybe you do???
Just the yoke - somebody must have run mine with bad u-joints for a while as the new u-joint is sloppy - the yoke cups are about .100" wider than the u-joint.
Yes - American made Precision Joints! - i'm pretty sure the yoke is worn (ever had that happen before?)
Let me know what you have.
Thanks,
Andy
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 12-10-2006, 08:43 PM   #2
uncle
Re: WTB - ASAP = Rear End Yoke for a '71 K-10 (4x4 1/2t)
I would think that it's a 12 bolt and if so any 12 bolt truck should work.
uncle is offline   Reply With Quote
Old 12-10-2006, 09:38 PM   #3
arkracing
Weekend Warrior
thanks for the info. Yeh it probably is a 12 bolt. I don't know wtf it is to be honest - all i know is that the U-Joint doesn't fit - I stuck a couple of small washers in it for now just to hold the cups from sliding around (the truck isn't drivable @ this point anyway)
-'66 C10 Suburban
Old 12-10-2006, 10:10 PM   #4
ZOOMY
You must not have the correct U-joint. Did it seat OK in the driveshaft side ?
ZOOMY is offline   Reply With Quote
Old 12-10-2006, 10:22 PM   #5
msgross
msgross's Avatar
will a front yoke off a Dana 44 work for ya?
msgross is offline   Reply With Quote
Old 12-10-2006, 10:56 PM   #6
arkracing
Weekend Warrior
Fit's fine in the Driveshaft - fits fine on the transfer case
(they don't make a u-joint that is .100" longer on one axis than the other, the closest thing is a #134 U-joint which is about 1/4" longer on 1 axis and is way too long for the rear end yoke)
I did a post in the '67-'72 info board with some more info as well.
http://www.67-72chevytrucks.com/vboa...d.php?t=219132
D44 will be different
Pretty sure it has to be from a '71-'71 C or K 5-10
-'66 C10 Suburban
Old 12-11-2006, 07:53 AM   #7
Blazerb61
I have that rear end yolk its about 1 1/2 years old Id take 50 for it plus the ride I paid over 80 for it
Blazerb61 is offline   Reply With Quote
Old 12-12-2006, 09:36 PM   #8
arkracing
Weekend Warrior
PM Sent
-'66 C10 Suburban
