Old 12-10-2006, 08:48 PM   #1
Southedisto
River life......
Southedisto's Avatar
Van tilt ???
Does anyone have picture of what the column looks like under the steering wheel? Does it have the retainer, or is the nut the retainer? Thank in advance. I searched couldnt find anything.
Southedisto is offline   Reply With Quote
Old 12-10-2006, 09:14 PM   #2
Bob Moore
Re: Van tilt ???
After the wheel is removed you will find the horn contact/turn cancel cam. Under that is a spring and then the turn signal switch. There is an odd sized fine thread nut on the column stub that regulates the slop. It requires an odd size and VERY deep socket. It is almost easier to remove the turn signal to access this nut.
Somewhere on the forum is a blow-up diagram of the column.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 12-10-2006, 09:19 PM   #3
Southedisto
River life......
Re: Van tilt ???
That is what I was hoping, didnt know if they were like the newer ones with the retainer disc.
Old 12-10-2006, 11:33 PM   #4
Bob Moore
Re: Van tilt ???
No PITA retainer plate. I have the special tool to remove the plate and it is still difficult.
vac, 454, T400
more to follow
Old 12-11-2006, 04:09 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Van tilt ???
you talking about the lock plate?
only a column with a locking steering wheel will have a lock plate. You can remove the lock plate w/out the depressor tool... but I have yet to reinstall it without the tool though. (yes, I do own one)
Old 12-11-2006, 04:46 PM   #6
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Van tilt ???
this is a truck but unless it has the lock in the column it should look like this.
sneakysnake is offline   Reply With Quote
