Old 12-10-2006, 08:49 PM   #1
KSCHEVYUP
KSCHEVYUP's Avatar
Question Question about center dash air conditioning vent
This is my first at working on an air-conditioned truck and I want to replace the center louvered dash vent and hoses. To anyone out there that's been there before me: How do you get it out and what all do you have to remove to get access to it? Thanks for any and all input in advance. KSCHEVYUP
1972 C30 Cheyenne Super
1971 C10 (Parts truck)
KSCHEVYUP is offline   Reply With Quote
Old 12-10-2006, 09:05 PM   #2
Bob Moore
Re: Question about center dash air conditioning vent
Darn near everything - lol. It has 2 studs that have nuts from the the front of the cab. Depending on how thin and flexible your arm is you may be able to do without much difficulty. If I were putting an interior back together it would be just about the first thing I would do - before the cluster, radio, A/C controls and the glove box.
Have fun and good luck - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 12-10-2006, 09:20 PM   #3
neonlarry
neonlarry's Avatar
The best way to get at it is to remove the glove box, so much easier especially if you have a radio..
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 12-10-2006, 11:27 PM   #4
Aarons72s
Yah pita! glove box has to come out and cluster removed to helps. Ive done it with the cluster in once, replaced the ducts, and that was the only time I will ever do it with the cluster. Be sure to have a new glove box liner to. I guarantee you will need it. Oh and the glove box door has to come off to get the box out and back in. Hope this helps.
Aarons72s is offline   Reply With Quote
Old 12-11-2006, 09:11 AM   #5
KSCHEVYUP
KSCHEVYUP's Avatar
Thanks for the input;
Aarons 72s- You were right about the glove box; but I've got a new one from GMC Pauls sittin right here.
Bob Moore and Aarons 72's both refer to removing the cluster?
Are they talking about the defrost/air conditioning hoses or something else?
Old 12-11-2006, 10:01 AM   #6
JimKshortstep4x4
They are referring to the instrument cluster as the left side hose does a 90 degree turn very close to the instruments.
When I reassembled the center vent, I only used the right side hose, blocking off the left side at the distribution outlet and the left side of the center vent.
It makes it easier to reassemble, although there is not as much airflow discharged from the vent. (The air flow is directed more toward the driver with the left side blocked).
Jim
Old 12-11-2006, 12:17 PM   #7
Andy4639
Old member
Andy4639's Avatar
I also plugged the left side of this vent and I think it helped with air flow myself. You only have three hoses feeding the 4 outlets counting the two hoses for the center. I personally think it's better.
Take the glove box out with door and take a 7/16" rachet and take the 2 nuts off the vent inside the dash. There is no need to take the dash cluster out that I know of.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
