Old 12-10-2006, 09:12 PM   #1
sleepyboy
'69 Step
How to attach stainless steel angle irons to stepbed?
I have new stainless angle irons for the side of the step bed. I have removed the old ones which were spot welded. How do I attach stainless ones? I usually MIG weld other things, but isn't there a special process with stainless? What have the rest of you done? Bolts, cold weld? Liquid nail type adhesive? I am just afraid of ruining the finish on the angle irons. Help??
sleepyboy is offline   Reply With Quote
Old 12-11-2006, 09:22 AM   #2
sleepyboy
'69 Step
Re: How to attach stainless steel angle irons to stepbed?
anybody??
Old 12-11-2006, 09:32 AM   #3
Sammy
I will be doing this too. I think if you check MARK K they say bolt or weld. Since they are stainless I am thinking stainless hardware. That was my thought anyway.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 12-11-2006, 11:07 AM   #4
jhow66
jhow66's Avatar
On my '65 GMC step I am using stainless button head bolts. My angle is painted steel.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-11-2006, 11:33 AM   #5
cdowns
cdowns's Avatar
bolts or rivets
Old 12-11-2006, 01:35 PM   #6
Myself
You can weld it if you want to with your MIG. The area around the weld will turn blueish though.
Myself is offline   Reply With Quote
Old 12-11-2006, 02:40 PM   #7
Bad71chev406sbc
Bad71chev406sbc's Avatar
tig....I don't know if the mig will stick to the stainless AND the steel. heck, I don't even know if a tig will stick....probably will with the right filler rod.
'71 SNB, 406sbc, TH350 w/ Transpak & Starshifter, 12bolt w/ 3.73s, 2" Early Classic front coils, 2.5" Flowmaster Super 40's
Bad71chev406sbc is offline   Reply With Quote
Old 12-12-2006, 12:47 PM   #8
Myself
Yes MIG will stick just fine to stainless.
Old 12-12-2006, 12:50 PM   #9
sleepyboy
'69 Step
But it will discolor it, right? I am not afraid of burn-thru bacuase I am a 1/2 a** welder, but will the discoloration buff out? I'd rather NOT use bolts if not needed..
