Old 12-11-2006, 04:39 PM   #1
04Xrider
Registered thread killer
04Xrider's Avatar
Easy way out auto column.
Just thought I would share the pics of this standard column I converted to auto. I plan on getting a Iditit at some point but for now this works fine. Lokar shift linkage $44.00, gear selector and pointer $35.00.
04Xrider is offline   Reply With Quote
Old 12-11-2006, 10:24 PM   #2
slepysal
slepysal's Avatar
Re: Easy way out auto column.
good job !!
slepysal is offline   Reply With Quote
Old 12-12-2006, 09:34 PM   #3
roj2323
oooo cool, so how did you like the lokar shift linkage? was it pretty easy and straight forward to install? i'm planning on using one for my 69 gmc so i figured i'd ask. oh hey are the gear selector and pointer lokar too? any info especialy product numbers would be awsome!
thanks,
ondrew
roj2323 is offline   Reply With Quote
Old 12-12-2006, 11:22 PM   #4
04Xrider
04Xrider's Avatar
The lokar kit was pretty simple, although because I have my engine sitting in the 6 cyl. position rear mount position, I had to add about 2 inches to the shaft to make it long enough to reach. After it is conected, you just have to play with the position of the shaft on the slot to make your pointer index right on the selector letters. Here is where I picked up the gear selector. http://cgi.ebay.com/ebaymotors/ws/eB...0616897&rd=1,1 I also had to trim some plastic off the selector to get the bracket to sit down on the column, no big deal.
