Old 12-11-2006, 07:27 PM   #1
Imacarguytoo
Hei install question
OK on my 67 its got a 350 in it with points distributor. Ive installed a hei. There are 3 wires under the dash going to a silver box. Pink,green, and black. The pink wire went to the + side of the coil. What wire down at that box do i need? Also do i not use that box at all? The only wires i see coming from the fuseblock is the green and the black wire.
Imacarguytoo is offline   Reply With Quote
Old 12-11-2006, 07:31 PM   #2
Southedisto
River life......
Southedisto's Avatar
Re: Hei install question
http://67-72chevytrucks.com/vboard/s...ht=hei+upgrade
http://67-72chevytrucks.com/vboard/s...ad.php?t=17403
http://67-72chevytrucks.com/vboard/s...ad.php?t=13698
Southedisto is offline   Reply With Quote
Old 12-11-2006, 07:36 PM   #3
Imacarguytoo
Thanks but that doesnt help me.
Old 12-11-2006, 07:38 PM   #4
corn
Got a pic of the silver box? Something aftermarket?
corn is offline   Reply With Quote
Old 12-11-2006, 07:47 PM   #5
Imacarguytoo
After my family goes to bed Im headed back out to do the wiring. Im just going to run a wire from an open spade in the fusebox to the dist. I will post back later and hope i can tell everyone i got it running.
Old 12-11-2006, 07:50 PM   #6
kelsfine69
18 Till I Die
kelsfine69's Avatar
Run a good Power wire from the fusebox so you have 12v in the start and run position. 0v in the off position. Plug tach wire in if you have one... next to the 12v on the distributer. Lose the silver box. Should fire...
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 12-11-2006, 08:00 PM   #7
Slammed70
Slammed70's Avatar
Thats what I did, 10Ga with a 30AMP inline fuse. Never had a problem.
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 12-11-2006, 09:45 PM   #8
corn
Just make sure it has juice in the start & run position & you will be fine. Thats how I did mine...
Old 12-11-2006, 09:48 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
is that box close to the fuse box?
Sounds like the horn relay, but why it was wired to the coil...
Old 12-11-2006, 10:45 PM   #10
truckdude239
truckdude239's Avatar
thats what i was thinking does it look like this? http://www.partsamerica.com/ProductD...pe=409&ptset=A
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-11-2006, 11:53 PM   #11
jhow66
jhow66's Avatar
Horn relay--pink wire is hot all the time-green wire goes to horns-black wire to horn button.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-12-2006, 12:00 AM   #12
Imacarguytoo
Yes it was the horn relay.
I flooded it, plus i cant check for spark right now. Wife is asleep. I guess im gonna have to have her help in the morning before she leaves for work.
Old 12-12-2006, 12:05 AM   #13
boot85
71 Chevy
I have always used the unfused terminal right off the fuse box. It is wired to turn off with the key. You can also put a fuse in the wire that you run to the distributor. I think that is the easiest way to hook up an HEI in a points vehicle.
71 C10
72 C20
62 Chevy II 2DR HT
boot85 is offline   Reply With Quote
Old 12-12-2006, 12:10 AM   #14
rage'nrat638
rage'nrat638's Avatar
hey you have a HONKING HEI j/k hope you gett'er done..
welcome to the board and where you at in il
rage'nrat638 is offline   Reply With Quote
Old 12-12-2006, 12:55 AM   #15
timcos
Chief Honcho In Charge
timcos's Avatar
I just did my HEI upgrade last weekend. I feel like I have a brand new truck.
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 12-12-2006, 10:46 AM   #16
Imacarguytoo
OK so far it wants fire but it backfired out the exhaust. Is it 180 out? I just stopped there till i get a reply.
Thanks for the help.
Old 12-12-2006, 11:08 AM   #17
dave2953
Dave's not here, man
dave2953's Avatar
Have you re-checked your firing order? 1 8 4 3 6 5 7 2 in a clockwise rotation
I would check that first. Also, is #1 at TDC? If you're having trouble finding TDC you can pulled the driver's side valve cover and make sure both valves are closed on #1. Keep us posted.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 12-12-2006, 01:05 PM   #18
Imacarguytoo
ok i checked with a volt meter. I have 12 volts at the wire at the dist with ignition on. I have it at TDC with #1 valves closed. I am getting gas. I have the firing order correct Ive checked that 4 times to be sure. I have the rotor button facing #5 cylinder. if i remember right thats the way i have done it years ago.
I am still getting small backfires out the carb. I am at a loss right now.
Old 12-12-2006, 01:13 PM   #19
OLDCHEV4X4
OLDCHEV4X4's Avatar
The rotor has to face no.1 at TDC
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 12-12-2006, 01:26 PM   #20
dave2953
dave2953's Avatar
The rotor button has to point towards whichever piston is TDC. Once you reposition it you should be good to go. I know it's kind of a PITA, but you'll be glad once you're done. HEI is well worth it!
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 12-12-2006, 03:42 PM   #21
Imacarguytoo
It still wont run. Im going to change to another hei i have. I hope it works this time.
Old 12-12-2006, 04:17 PM   #22
manimal
manimal's Avatar
You can also go to NAPA and get the factory style fuse block connectors(spade type expand and lock into place),take off the firewall connector remove the resistor wire and connector and replace it with the new 12/10 gage wire to the HEI and your done.Plus it gets rid of the EXTRA wires!(resistor and yellow)
manimal is offline   Reply With Quote
Old 12-12-2006, 04:56 PM   #23
Imacarguytoo
Guys i have almost 2 days in doing this. I cant get it to run. im at a loss and no idea what to do. Ive got the other hei installed and still NOTHING.
Old 12-12-2006, 05:17 PM   #24
Imacarguytoo
i put the motor at TDC took the driver valve cover off. Both #1 valves are closed. I set the dist in to where the rotor is pointing to the number 1 plug. I had my wife turn the motor over this morning to make sure i had spark and i do. I am getting gas. I checked with a volt meter at the dist to make sure i was getting 12 volts and i am. I dont know what to do..... I can take pics of every stage if need be...
Old 12-12-2006, 05:57 PM   #25
Longhorn Man
ok, please forgive me if this sounds like i am treating you like an idiot... but I have seen this happen more than once.
You say when the piston is at TDC on cylinder #1 (dvr front plug) that the rotor is pointing to #1....
here's where I hope you don't get insulted...
is it pointing to the #1 cylinder...as in on the engine... or the terminal that holds the plug wire that runs to the #1 cylinder.
I've seen it happen more than once.
