12-11-2006, 07:30 PM | #1 |
Can you decode this VIN??
My book shows nothing like this #
CE148Z......
70 GMC shortbed fleetside with a 72 chevy costume Last edited by 72dually; 12-11-2006 at 07:38 PM. |
12-11-2006, 07:39 PM | #2 |
Re: Can you decode this VIN??
C=2wd
E=V8 1=1/2 ton 4=cab w/ pickup bed 8='68 Z=Flint, MI plant
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck Last edited by Robert1970C20rstbukt; 12-14-2006 at 01:59 AM. |
12-11-2006, 07:58 PM | #3 |
member #16
Here is a Sample VIN and Model Number for a 69' Chevy Pickup
-------------------------------------------------------------------------------- 1967-1972 VIN Number Codes Example: CE149J 100001 Chassis Designation (1st digit) C= 4x2 K= 4x4 Engine Deisgnation (2nd digit) E = V-8 Gas S = Six Cylinder Gas GVW Range (3rd Digit) 1 = 1/2 Ton 2 = 3/4 Ton 3 = 1 Ton Model Code (4th Digit) 4 = Pickup with Cab and Bed Model Year (5th Digit) 7 = 1967 8 = 1968 9 = 1969 0 = 1970 1 = 1971 2 = 1972 Assembly Plant A = Atlanta B = Baltimore F = Flint J = Janesville N = Norwood P = Pontiac S = St. Louis T = Tarrytown Z = Fremont 1 = Oshawa Vehicle Serial Number 100001 = 1st Unit Built 1967-1972 Model Number Codes (The Model Number is located on the inside of the glove box door.) Example: C E 1 09 9 34 J 100001 Chassis Designation (1st digit) C = 4x2 K = 4x4 P = Forward Control Engine Deisgnation (2nd digit) E = V-8 Gas S = Six Cylinder Gas GVW Range (3rd Digit) 1 = 1/2 Ton 2 = 3/4 Ton 3 = 1 Ton Cab To Axle Dimension (4th Digit) 07 = 42"-47" 09 = 54"-59" 10 = 60"-65" 12 = 72"-77" 13 = 78"-83" 14 = 84"-89" 15 = 90"-95" Model Year (5th Digit) 7 - 1967 8 - 1968 9 - 1969 0 - 1970 1 - 1971 2 - 1972 Body and Brake (6th Digit) 02 = Flat Face Cowl 03 = Cab 04 = Stepside Pickup 05 = Panel 06 = Suburban 09 = Cab, Platform, and Stake Rack 12 = Windshield Cowl 16 = Suburban (Tail and Liftgate) 26 = Custom Suburban (Panel Rear Doors) 34 = Fleetside Pickup 35 = Foward Control (Square Front) 36 = Deluxe Suburban (Panel Rear Doors) 42 = Forward Control Chassis 45 = Forward Control Panel (Round Front) Assembly Plant A = Atlanta B = Baltimore F = Flint J = Janesville N = Norwood P = Pontiac (GM Truck) S = St. Louis T = Tarrytown Z = Fremont 1 = Oshawa, Ont., Can. Vehicle Serial Number 100001 = 1st Unit Built
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
12-11-2006, 08:34 PM | #4 |
Thanks Robert and John.........you guys are a great help, and its appreciated
It is indeed a 68
70 GMC shortbed fleetside with a 72 chevy costume |
12-11-2006, 09:55 PM | #5 |
its all about the +6 inches
just remember, as john typed, that 4 means cab and bed... NOT step side. Very common mistake thanks to LMC and 75% of the internet just copying what LMC says.
12-11-2006, 11:13 PM | #6 |
I was wondering about that Longhorn, Thanks
12-12-2006, 01:53 AM | #7 |
Wow, I didn't know that either...
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
12-12-2006, 01:30 PM | #8 |
Like I said... VERY common. I came here january of 01, and that was like my second question I had.
12-14-2006, 02:00 AM | #9 |
I fixed my post, thanks John for correcting me on that.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
12-15-2006, 12:27 AM | #10 |
Hmm..well you might as well fix the assembly plant too... Z is Fremont not Flint.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
