12-11-2006, 09:47 PM | #1 |
Where to find NP205?
Well,I am on a mission to find a np 205 t case for my shortbed K10.I havent had much luck finding just a transfer case locally and any I find online are to far away to pick up and they cant be shipped because of the weight.I am now considering buying a complete truck just for the transfer case.Ok,and now the question....What Chevy or GMC trucks came with a np 205 stock?I know they were in 71-72 4x4s stock and they were in 73-87's with a manual tranny,correct?But what years did they come with the NP205 with an automatic tranny?I need to know what years of trucks to concentrate my search on so I can find one.All the trucks I have found have only turned out to have Np203 t-cases and I am not putting one of those in my shortbed.I guess if I still cant get one I will shove in of my spare rockwell T221's in it till I do find one but the longer I am without it the longer the truck is apart and I am trying to get it back together ASAP.So if someone could tell me what years and models to look for I would really apprectiate it.
12-11-2006, 10:29 PM | #2 |
Re: Where to find NP205?
Must be a shortage in Indiana, I'm always tripping over them in the local wrecking yards. BTW I have about 7 of them---all rebuilt with various adaptors.
12-11-2006, 10:32 PM | #3 |
There must be a shortage.I went to the junkyards and found alot of 4x4s but they all had np 203s and 208s.Couldnt find any np205s.
12-11-2006, 10:51 PM | #4 |
River life......
Have you checked craigslist?
12-11-2006, 11:51 PM | #5 |
Yeah,I have and came up with no luck.I did however find a very cheap 72 LWB K10 that has a np205 and for the price I am considering buying it and besides getting the transfer case I will have another lifted 4x4 to add to my stable if I keep it after I pull the transfer case.
12-12-2006, 05:38 PM | #6 |
Aluminum slot wheels rule...
Dustin, I bought mine for 50 bucks, along with the SM465 it was mated to, out of a 1970 K10 and any other parts I wanted off the truck. (never did get any parts off of it ) The t-case works, but it's got some play in it, and probably could use a rebuild someday. I'd look around in the classifieds, and keep checking junkyards.
12-12-2006, 07:14 PM | #7 |
Sounds like you got a good deal there.I am still checking around but havent had much luck finding one.If I was looking for a np203 there would be 205s everywhere so maybe I should temporarily change my search
12-12-2006, 07:46 PM | #8 |
Try JAMIE72---he has some and is just north of Madison, In---just down the road a piece from you.
12-12-2006, 09:18 PM | #9 |
Ok,back on subject and back to the original question posted:
Can someone give me some info on this? |
12-12-2006, 10:03 PM | #10 |
FNG to resto/mod world!
This is from the "short episode on the soapbox" thread-
Quote: Originally Posted by LONGHAIR Generally all you need to do is find out what transmission is in the truck. An automatic transmission will have a 203 and a 4 speed will have the 205. When you get up into the early 80's they have NP208 cases. This a totally different slip-yolk unit. I'm not sure that is true - I have a 4 spd in my 75 K25 & its a NP203. It's been converted to part time like it should have been in the first place, but none the less a 203. I would think the confusion would be with the 205 & 208 since thay have the same shift patterns - the 203 has from front to back: Low Lock, Low, N, Hi, Hi Lock. Just sharing what little I know.
71 GMC Jimmy - under construction 75 GMC K25 Sierra Grande - under deconstruction 92 Chevy K2500 ECSB - sold 04 Nissan Titan ECSB Off Road - sold & missed 13 Ford F-150 Ecoboost (work truck) - sold 16 Ford F-150 Ecoboost (work truck) |
12-13-2006, 01:34 AM | #11 |
Not all 205s will fit either, as the early married GM cases had the figure-eight bolt pattern (what you need). Later ones went to the more standard 6-hole round pattern.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
12-21-2006, 12:33 AM | #12 |
How far ya willin to drive? I just brought home a chassis that has a 205 in it. I'm in the very northeast corner of Missouri.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
12-21-2006, 12:53 AM | #13 |
My 73 K20 with a 454 /TH400 had one. Had being the operative here. I don't know how plentiful they are anymore,
but it gives you something to shoot for.
'96 K2500 GMC 6.5 4L80E '88 c1500 RCSB lowered 4 & 6 454 TH700R4 (still being built) '79 K20 Chevy 400 4 spd '69 K20 Chevy 406 4spd '70 K10 Chevy 355 4spd 6 inch lift '70 C-20 (son's truck) originally 292 4spd now a 350 4spd Hey I didn't even want to until you told me I couldn't ! |
12-21-2006, 12:56 AM | #14 |
I dont think my truck could make it the far to be honestYou are talking about that Jimmy that Randy had for sale right?I figure I might be able to go a distance to a certain point for a whole truck because I can never own too many trucks but my yard cant hold many more trucks scattered in hundreds of parts and it will be time to start mowing before too many more months and grass grows faster than I can build trucks.
12-21-2006, 08:43 PM | #15 | |
Active Member
For those of you wanting to add an indicator light that lets you know when you are in 4 wheel drive, the part number is 15594176 for the switch that screws into one of the shift rail holes. Hope this helps somewhat even though i don't know all the details.
Mike T. Oregon 70 GMC Jimmy 4x4 70 Camaro LS1 plans in the works 71 RS/SS Camaro numbers matching 86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear) |
12-21-2006, 08:48 PM | #16 |
Thank you for the info,I think the best bet at the time would be to look for a 67-72 with a np205 and know I have the right t case
12-21-2006, 08:49 PM | #17 |
i have acouple np205 cases not sure really what there worth live in nw indiana if that helps at all.
12-21-2006, 10:25 PM | #18 |
I have a 205 from behind a turbo 350 out of my 72 parts blazer. I'd like 150 out of it. I live just south of Interstate 74 4 East of Illinois.
Thanks Troy
69 Chevelle SS 375/396 TKO 600 71 Suburban 3/4 4x4 402 5-speed (project) 68 chevy C10 shortbed 327 5-speed (project) 72 Blazer 4x4 400 4-speed (wifes project) Numerous 67-72 parts trucks |
12-22-2006, 02:51 AM | #19 |
What trans are you planning on running? (Or did I miss that part?)
Anyway, just FYI, there are 4 different input designs for the 205 in GM trucks that I know of. Your best bet is to get a 205 that was originally behind whatever transmission you're planning on running. Here's the input/trans combos that I know of; 205 Input Trans 10 spline male SM465 4 speed 27 spline male TH350 Auto 32 spline female, (short) TH400 32 spline female, (long) Later model 4 speed? (Not sure if these are still the SM465 and the "long" female input may have also been behind some TH400 transmissions? Not to familiar with the "long" input. Here's some more; the 10 spline and 27 spline male input 205's use a smaller input bearing than the 32 spline female input. So, for example, if you were going to run a 4 speed, (10 spline), or a TH350 trans, (27 spline), the 32 spline input 205 cannot be used. You can't change the input to the smaller bearing inputs because the hole in the case for the bearing is to big. Now on the other hand, if you were to go the other way around, you can always have the smaller bearing hole machined out to fit the larger input bearing. Hope you can make sense of all that.... Here's an old thread of mine that might interest you also; http://67-72chevytrucks.com/vboard/s...d.php?t=193260
12-22-2006, 11:46 AM | #20 |
I am pretty sure at this point that I am putting a TH350 in it.I would have liked to put a standard tranny in it but I dont want that low geared SM465 in it and I dont want to modify the truck all that much for a 5 spd so a TH350 will go in it.
12-22-2006, 11:47 AM | #21 |
Thanks to everyone for the info. Troy-built and I have set up a deal and I am supposed to be buying his transfer case,and a few other items I need, and pick it up next week.Looks like my search will finally be over and I can get this truck going.
Thanks to all and Merry Christmas! Last edited by 1969k10stepside; 12-22-2006 at 11:48 AM. |
