67~68 Buckets: Original or Modify?
I have a set of original buddy buckets for my 68 that are in so-so shape w/some surface rust on the console 'compartment'. The seats will most likely require new foam but are mostly intact.
My dilemma is I want to permanently mount my air-ride stuff while keeping it inconspicuous & I'm considering modifying the console to accomplish the task. My idea is to mount the 'switches' in/on the front of the console compartment (under the front lip of the seat foam). I would like to be able to reach down to the front of the console/seat & make height adjustments, but keep everything hidden otherwise. I still have to figure where to mount the gauges & want to keep them inconspicuous as well (mounting them in the 4-lower holes of the factory gauge cluster would work if I could match all the gauges..... anything besides hanging them in plain view under the dash line). It's not like the console compartment is some ultra-rare, unobtainable item.... it's a sheetmetal box that could be duplicated if necessary (or the area that is modified for the switches could be replaced just like you would do when filling in a side-marker light). What do you think?
Born Psycho
![]() Join Date: Feb 2001
Re: 67~68 Buckets: Original or Modify?
sounds like a good idea to me, the box is same as the one used by dodge so a spare isn't too difficult to get, should you decide to go back original.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
A guy with a truck
I was thinking the same thing, only use a hinge style ashtray for the mechanism to have it all swing out when you want it and be hidden when you don't. Hides everything- see crummy pic: Circles are gauges, squares are switches...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
The ART style gauges I have are pretty deep (not sure they would allow the pivot vs. the depth of the compartment).
I originally was thinking of just putting them in the console compartment facing the headliner but thought mounting the switches withing reach on the front wall of the compartment & having the gauges in sight would be better.
#5 | |
![]() Join Date: Apr 2005
Scotti, Are you still considering this modification? If so I got a box that someone has already modified and am looking for an original box. If you are still planning on doing this, wanna trade ? ![]()
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Happy to be here
![]() Join Date: Mar 2000
Your gonna want the gauges where you can see them when rolling. Beyond that I say cut it up. It's only metal...
#7 | |
Forward some pics of your modified box if you can. If the area that I would be modifying is the same, I'm sure we could work something out.
Here are some pics. The front of the box was cut to put in the wooden cup holder.
