Old 12-11-2006, 11:40 PM   #1
1987 Shortwide
I HAVE to do something about my steering...
As you see here, this is the current "manual steering" rig up.
We just finished dropping a vortec headed 355 in my buddy's 86 stepper and tuned it tonight. I've driven many cars with manual steering, but that truck was the WORST! I know now that if I manage to get loose at half track it's over, there's no quick correcting this sucker....
So what to do? I really REALLY don't want a PS pump on it. I want nothing more than the alternator to run on a belt, the waterpump is electric.
Roll her into the chassis shop for a flaming river rack install, or order up a C-4 drop member with manual rack? Drop member would be a bit more than the rack install on my setup, but it'd sure look and perform better...
~Steve~
Friesen High Performance Auto and Graphics
Toy: 87 Shortwide, 406 smallblock with a little boost
My 87 buildup
Daily Driver: 99 Sierra SLE 4X4. Black on Black and harder than hell to keep clean.
1987 Shortwide is offline   Reply With Quote
Old 12-12-2006, 12:35 AM   #2
bigblock73
yeller
bigblock73's Avatar
Re: I HAVE to do something about my steering...
Make the truck a wheel stander...then you don't need PS...just hand brakes for the rear to steer.
Sorry man, that is all the help I can offer. Your frame sure looks nice though!
bigblock73 is offline   Reply With Quote
Old 12-12-2006, 01:44 AM   #3
1987 Shortwide
hah, gee thanks jeff, you're just the man with a plan tonight, huh. LOL
Oh well, I figure at my current rate, I've got some time to choose...
~Steve~
My 87 buildup
Old 12-12-2006, 11:43 AM   #4
Zoomad75
K5Camper
Zoomad75's Avatar
If all you are using right now is a p/s gear with that jumper hose, it's going to steer like crap. It's no different than a truck where the pump went out, hose ruputre or other failure. What I mean is p/s gears were designed to use the fluid to ease the effort of turning. Take the fluid away and they are worse than true manual steering gears.
Going to a rack & pinion would be the ultimate, but finding a true manual gearbox would be the shortest route to your solution. I'm not sure that many trucks of the 73-87 range were built without p/s but I'd bet the earlier ones from 73-75 would have a greater chance. Even auto zone lists a manual gear part when you look up a 73 c10.
It wont steer as easy as one with p/s but it would be better than a p/s gear without a pump.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 12-12-2006, 12:04 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The manual boxes on these are potheticly slow and a real bear. I swapped mine out because a 454/4speed power brick wasn't fun to counter steer.
Are you avoiding the power setup because of the parasitic loss from the pump or because you don't want anything mounted to the motor? Or because of weight?
Options
1)Manual rack
2)driveshaft driven power steering pump
3)2nd Gen Toyota MR2 ELECTRIC power steering pump. (I understand that the EV1 and Subaru have them also... not sure though)
There are also cars with electric pump and racks... In fact flaming river has an electric steering....
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-12-2006, 06:00 PM   #6
Zoomad75
K5Camper
Zoomad75's Avatar
I'm betting he don't want the pump for the parasitc power loss. That being said, you could probably use a smaller pump off of a cavalier with a remote reservior (the aftermarket serpentine kits usually use that type of pump). I'm betting, besides the easier packaging, its probably more efficient than the giant stock p/s pumps on these trucks. Yes it's going to still pull power from the engine, but if your making big power you probably wouldn't notice it. You could probably make it up by loosing some wieght in the truck elsewhere.
I can understand the want to get every drop of power to the tires, but is it track only or a semi-street driven? I had a buddy gut a 72 nova to gain speed, even ditched p/s and p/b to loose wieght and parasitc power loss. He gained maybe .5 sec and made it darn near impossible to drive on the street. He did drive it on the street too. Just didn't make much sense to me as I watched him skid by me at the track with the manual brakes locked up to make the first turn off the strip.
Rob Z.
Old 12-12-2006, 06:14 PM   #7
hiway
Mad Scientist
Just put a manual box on it from another truck...had lots of them. You'll be happy.
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 12-12-2006, 07:11 PM   #8
1987 Shortwide
Partially because I don't want more on a belt than needed, partially weight. Mainly it's just because I'm a picky bastid and I don't want a power steering pump and lines under there if I can avoid it. I'm going to look into racks, and if I absolutely HAVE to, I guess I'll look into a nice billet PS pump with a remote res.
~Steve~
My 87 buildup
Old 12-12-2006, 11:56 PM   #9
magnethead
7000 #'s of american IRON
magnethead's Avatar
as said, go electric. If you do the math right you can make the motor for an elec water pump probably spin a p/s pump just fast enough to build pressure.
as to pump drag, my truck has hydroboost, and i loose 200 RPM while turning from the drag, even worse if i'm braking and turning at the same time.
magnethead is offline   Reply With Quote
