Old 12-12-2006, 10:30 AM   #1
76bonanza
76bonanza's Avatar
kind of silly question
I have a small leak from the base of my water neck. I will be hopefully fixing over the holiday. Anyway I have one of those blue shop paper towels wrapped around the base of the water neck so it wont run all onto my intake.
It wont get hot enuf for that thing to catch fire will it? A freind of mine mentioned it but I dont think it gets nearly that hot there. Maybe if you wrapped it around a header or something. Anyway got me wondering.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 12-12-2006, 11:48 AM   #2
cdowns
cdowns's Avatar
Re: kind of silly question
air flow can move it easily to the exhaust header
Old 12-12-2006, 04:51 PM   #3
76bonanza
76bonanza's Avatar
Ok I ordered a new waterneck and thermo from summit. I got the cheap billit summit water neck that uses the o-ring. My question is should I use some rtv on the bolts do they pass into the water jacket? And with the o-ring one I use nothing else just the o-ring right?
thanks
1968 c10
lowered 3" 4"
Old 12-12-2006, 05:07 PM   #4
bryanw1968
bryanw1968's Avatar
thanks
Use just the O-ring. It wouldn't hurt to put some non-hardening RTV or Old Indian Head gasket sealer from Permatex on the bolts only.
bryanw1968 is offline   Reply With Quote
Old 12-13-2006, 09:45 AM   #5
76bonanza
76bonanza's Avatar
One more question about how much coolant should I drain to make the thermostat swap? the coolant is only about 6 months old dont want to waste it but dont want to drain to little and make a mess also.
1968 c10
lowered 3" 4"
Old 12-13-2006, 10:49 AM   #6
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Just drain it into a clean bucket,get the level down below the top of the motor then after your through put it back in.
sneakysnake is offline   Reply With Quote
Old 12-14-2006, 08:52 PM   #7
76bonanza
76bonanza's Avatar
one more question 2 do you wet the oring or use vasaline on it? Just other things with orings say this? Just curious
1968 c10
lowered 3" 4"
