Junior Member
1st gear problem on 3sd
I've had this problem for awhile and it's getting worse. Whenever I'm stopped and moving to 1st it's a fight. Usually its easier to force up to reverse then throw it quickly into first, que loud hammer sound. If I go to 1st while still rolling then no problems. The truck is a completly stock 1970. Is this a clutch adjustment problem? What do you all think? Feel free to ask for more info on specifics. It won't happen every time but becoming more frequent.
70 C/10 LWB 250 ![]() Last edited by 70c/10barebone; 12-12-2006 at 12:18 PM. |
![]() Join Date: Sep 2005
Re: 1st gear problem on 3sd
mine is like that but its not as bad i can get it in once i'm stoped but rolling nope wont go think the trans i put in the truck has somesort of safety in it
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Some of those old 3-speed do NOT have synched 1st gears, and are not designed to go into first unless you're stopped...
Have you checked your synch's to see if they're shot?
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
