Turn signal broke
whats the name of the little plastic piece inside the steering column that the turn signal lever screws into, my turn signals still work, but don't turn them selves off anymore, and I'm tired of drive 10 miles before I realize they're still on.
edit: oh by the way, I have a tilt column if that matters. Last edited by BrentRS1985; 12-12-2006 at 03:19 PM. |
Re: Turn signal broke
I'm pretty sure it is called a turn signal cam.
Try this site. http://www.manestruckparts.com/store...&Category_ID=8 Last edited by kyull67; 12-12-2006 at 03:24 PM. |
#3 | |
1969 C-10 Short Bed |
its all about the +6 inches
the part that the turn signal lever screws to is the switch it's self.
The cam is the round plastic piece that slides over the shaft and isn't bolted onto anything. |
It's called a trun signal switch cam, the part that slides over the shaft is called the cancel cam , parts are available to repair or just replace the entire switch. Try this link pages 48-49 for parts.
www.truckandcarshop.com Last edited by 68SHORTBOX; 12-12-2006 at 06:26 PM. |
If it's just a matter of turn signals not canceling, you most likley need a turn signal canceling spring.The hardest part is removing the wheel.You can get the springs at either the chevy dealer or local parts store.If you pull your wheel you will likley find a broken spring.that's what mine was.
http://www.truckandcarshop.com/trucks60_72/t60_049.html Last edited by chevyboy55; 12-12-2006 at 06:32 PM. Reason: forgot to add link. |
