Wheel housing seals
I'm getting prepared to put my bed back together. Is there some sort of seal that goes between the wheel housing and the bedside to seal out moisture. If so where do I get it. Thanks, Allen
72 Chevy A/C P/B P/S Tilt 454 Engine 400 TCI Trans C30 Frame C10 Suspension Short Wheel Base (Dually) |
Re: Wheel housing seals
I used dum dum, 3M makes in a box cut in 1/4" strips about 10" long, Napa
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
![]() Join Date: Jul 2004
I used seam sealer between there. Wiped off extra on top with mineral spirits and used my finger to leave a nice small bead on top.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
