Cochino_Racing_909
Need some Info!
Does anyone Know if you can inter change the axels on the 69-72 trucks? Meaning I have a 5 and also a 6 lug can these axels be interchanged?
sufficiently talented fool
![]() Join Date: Jun 2006
Re: Need some Info!
The axle lengths are different on some. I believe the mid 69 to 72 are the same, and the 67-mid 69 are the same . I could be wrong, i'm sure someone else will chime in to correct me....
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
Re: Need some Info!
I think centless has it right. The axle shafts are different lenghts. You can exchange the whole assembly. Remember that some axles are coil spring and others are leaf. This would be a different kettle of fish.
trailers are for boats |
Keepin an eye out
Re: Need some Info!
Axle lengths changed during the '70 model year to the longer ones.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
Re: Need some Info!
I agree. ^ About 3/4 of an inch longer per side.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
Re: Need some Info!
You can use the 5 lug axles as they say in the older 67-69 axle housing and go get drums for a 74-87 chevy truck with 11-5/32 brakes. The drum is 3/4" wider than stock and will work fine with the existing brakes,ie 2" brakes. I will go get a link for a thread on this modification.
Here is the linky: http://67-72chevytrucks.com/vboard/s...d.php?t=215095 Last edited by Aarons72s; 12-13-2006 at 04:18 PM. |
