Old 12-13-2006, 02:32 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
valvetrain readjustment question
i have owned my truck for about 3 years now and i rebuilt my motor when i got it. there has always been a valvetrain clatter but no lack in performance at all. i was wondering if i could go back after all this time and readjust the valves to see if i can stop the clatter. would a lifter be all beat up if it was bouncing around in the lifter bore for all this time?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 12-13-2006, 05:27 PM   #2
bryanw1968
bryanw1968's Avatar
Re: valvetrain readjustment question
What kind of rockers are you runnin'?
bryanw1968 is offline   Reply With Quote
Old 12-13-2006, 05:43 PM   #3
crm318
crm318's Avatar
all factory valvetrain.
1972 Cheyenne
Old 12-13-2006, 08:09 PM   #4
corn
If you have had parts loose enough to bang them around after running it this long you would have worse problems than noisy rockers by now. Id readjust them & see how it sounds. A couple loose ones will name a bunch of noise. You may even have a little more power when you are done. Got to be worth a try... Will you be doing a wet adjust or dry?
corn is offline   Reply With Quote
Old 12-13-2006, 08:29 PM   #5
Slammed70
Slammed70's Avatar
Solid or hydraulic?
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 12-14-2006, 02:06 PM   #6
crm318
crm318's Avatar
it is hydrolic flat tappet. how do you mean wet or dry? my plans was to rotate the motor starting at TDC and adjusting them using the firing order. i will make sure that both valves are closed and take the valve lash out and give them a half turn. what do yall think?
1972 Cheyenne
Old 12-14-2006, 07:42 PM   #7
corn
If you do this you will only need to turn the motor over once after you find TDC.
Turn the motor over until you are on 0 deg TDC, (both number one valves closed).
Adjust the #1 exhaust valve
Adjust the #1 intake valve
Adjust the #3 exhaust valve
Adjust the #5 intake valve
Adjust the #7 intake valve
Adjust the #2 intake valve
Adjust the #4 exhaust valve
Adjust the #8 exhaust valve
Now rotate the engine 360 degrees. The mark on the balancer should be back at the TDC mark. Keep in mind that this is not the TDC where #1 would be firing! It's where #6 would fire.
Adjust the #3 intake valve
Adjust the #5 exhaust valve
Adjust the #7 exhaust valve
Adjust the #2 exhaust valve
Adjust the #4 intake valve
Adjust the #6 exhaust valve
Adjust the #6 intake valve
Adjust the #8 intake valve
Your DONE!
A wet adjustment would be to run the engine & do one rocker at a time. Its easier to tell when its adjusted right but IT IS MESSY!...
Old 12-14-2006, 09:16 PM   #8
rage'nrat638
rage'nrat638's Avatar
Thumbs up Re: valvetrain readjustment question
The adjustment for hydraulic lifters is 1 turn down from zero.
In order for the hydraulic lifter to work correctly, it must be centered. . If
your valves have come out of adjustment after several thousand miles of
operation, suspect your rocker arm nuts, and replace them. They do wear out
after constant adjustments.
When adjusting your valves, tighten all adjusting nuts until all lash is
removed by feeling the rotation and up and down movement of the pushrod. Next, set your engine on
TDC #1, pointer at "0". You can now adjust the following valves:
INTAKE on cylinders 1,3,4,8
EXHAUST on cylinders 1,2,5,7
Loosen the adjusting nut until lash is felt by rotating the pushrod. Then
tighten the adjusting nut while rotating the pushrod until all lash is
removed. Now tighten the adjusting nut 1 full turn. This "centers" your
lifter.
After you have adjusted the above valves, rotate you engine 360 degrees
bringing the pointer around to the 0 TDC mark. This is TDC #6. Adjust the
following valves in the same manner:
INTAKE on cylinders 2,5,6,7
EXHAUST on cylinders 3,4,6,8
Your valves are now adjusted properly.
good luck and may the force be with you
rage'nrat638 is offline   Reply With Quote
Old 12-14-2006, 10:15 PM   #9
crm318
crm318's Avatar
thanks for the info and the visuals. when i get some free time this weekend, ill give it a shot.
1972 Cheyenne
