Old 12-13-2006, 02:59 PM   #1
bad_turbo
turbo enthusiast
bad_turbo's Avatar
draining tank
If I pull the fuel line off my in cab fuel tank, will that drain all the fuel out?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 12-13-2006, 03:26 PM   #2
gouldie
Re: draining tank
as long as the end of the line is below the lowest point in the tank physics says it will. you may need to get it started by sucking a little out.
67 c10 250 I6 3 on the tree no options
air ride, paint and big block coming within the next 23 years
2001 mustang gt for going fast
gouldie is offline   Reply With Quote
Old 12-13-2006, 04:18 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: draining tank
You can either run a piece of garden hose in the filler and siphone it out or put a piece of fuel line on the outlet line and siphone it like that. Just keep the end lower than the tank.
sneakysnake is offline   Reply With Quote
Old 12-13-2006, 05:01 PM   #4
49studebaker
49studebaker's Avatar
Re: draining tank
When I pulled my fuel lines off, it still left a few gallons in the tank, it sloshed from side to side big time as I cared it out of the shop. More so than you would think. If you can drain it completely it will be much better.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
