Old 08-20-2002, 05:14 PM   #1
WB72
Before and After
WB72's Avatar
Vortec Heads
Which year and type of vehicle are good candidates to transplant to a SB 350?
Are there any modifications that need to be done?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 08-20-2002, 05:35 PM   #2
Project1970
14.1 @ 96MPH
Project1970's Avatar
Vortec heads were introduced in 1996. You'll find them on any GM truck or SUV produced in 1996 or later, but before the current generation of trucks came out.
I don't think there's any mods that need to be done, aside from the fact that you need a new intake manifold to fit the heads, or machinework on the heads to fit standard intakes. One thing to note, they are 64cc heads...I've got some in the mail (my original heads are trashed, not worth the $450 of machine work they need) and it's probably going to bump my compression ratio on my original lower end to about 10.1:1 or so, it appears...should be interesting, heh. Just dumb luck that I happen to have an empty tank in it now, lol...gotta go to 92 octane from now on...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 08-20-2002, 06:11 PM   #3
Mixup
They make a thicker head gasket for those heads. I used them on my truck. I'm at work but I'll get the name and part number when I get home if you want.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 08-20-2002, 06:19 PM   #4
chevyman 68 C/10
chevyman 68 C/10's Avatar
Those heads are like kicking a sleeping junk yard dog. For a daily driver that you have to depend on they are a good choice, money considered
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air.
68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles
68 anniversary no engine long wheel base 400 auto FOR SALE
68 Chevy fleet side long wheel base complete parts truck.
chevyman 68 C/10 is offline   Reply With Quote
Old 08-20-2002, 07:08 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
There is no provisions for a mechanicle fuel pump on the new engines.
There is a bolt missing on the ends of the heads that may or may not be missed with your acc set up. (I can't remember which hole it is that is missing)
Then there is the dedicated intake you will need, along with special (96 and up) intake gaskets.
That should be all the draw backs of using a vortec engine.
Old 08-20-2002, 07:12 PM   #6
mikep
Used to have a truck
mikep's Avatar
Dont forget the special rocker arms and valve covers you'll need. Ive driven a few vortec equipped trucks and they run like that bat from hell everyone is always talking about.
No truck :-(
mikep is offline   Reply With Quote
Old 08-20-2002, 07:22 PM   #7
Longhorn Man
I was going to mention that, but he is looking for an entire engione, and we are asuming he does not wast to run the computer and fuel injection.
Old 08-20-2002, 09:48 PM   #8
Project1970
14.1 @ 96MPH
Re: Vortec Heads
I thought he just wanted to switch the heads...*shrug*
Old 08-20-2002, 10:03 PM   #9
Longhorn Man
Hmmmm, I guess I look like a jack @ss.
Old 08-20-2002, 11:26 PM   #10
Project1970
14.1 @ 96MPH
No, that would be 68SWB4X4.
Or maybe you would if you had Johnny Knoxville instead of Johnny Bravo.
Old 08-20-2002, 11:33 PM   #11
chevy garage
chevy garage's Avatar
I've seen the Vortec's in Jeg's for 250.00 ea. That is not a bad deal for a brand new head ready to bolt on. A set of double humps would cost at least 500.00. I'm wanting to try a set myself.
Jeg's actually sells them cheaper than a local Chevrolet dealer in town.
chevy garage is offline   Reply With Quote
Old 08-20-2002, 11:43 PM   #12
Longhorn Man
Not only are they cheaper, but in stock form they out flow anything (cast in Iron) that GM ever made in the past.
Old 08-21-2002, 04:36 AM   #13
Project1970
14.1 @ 96MPH
And they do pretty darn good compared to a lot of GM's aluminum offerings, too. They flow nearly as well as a set of LT1 heads (which, of course, don't work on a GenI block) - because the head design was taken right from the LT1. They even do better than the L98 Corvette head!
http://www.corvettefaq.com/c3/goodwrench/gm3504.htm is the Vortec portion of a buildup of the el cheapo GM Goodwrench 350...
Old 08-21-2002, 06:19 AM   #14
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Luckymic34 just bolted a set of vortec heads on his 68. I believe he paid $700 for everything, complete heads,intake and gaskets. Last I talked to him he said it really woke it up, hope to do it myself next year. chevy garage, those heads in jegs is exactly what I was looking at not a bad price for an extra 30 horses.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-21-2002, 10:57 AM   #15
WB72
Before and After
WB72's Avatar
Just Heads.
Yes, I would like to way the pros and cons of Vortec heads, or machining (port and polish)old heads that I already have, If I have to, I would get a new intake, I will be getting one anyway.
If I need an Intake, would Edelbroc (or any aftermarket company, for that matter) make them?
66,000 miles.
Alberta, CANADA
Old 08-21-2002, 12:25 PM   #16
Project1970
14.1 @ 96MPH
Edelbrock makes most of their manifolds available for Vortecs, I believe; I know there's the Performer, Performer RPM, and RPM Air-Gap. The Performer is the one that Scoggin-Dickey includes in their head kit.
I think that article over at Corvette FAQ put it best: "Generally, rebuilding a set of stock iron heads will cost in the neighborhood of $400 to $500. The problem with this is that all you have to show for five big ones is a marginal set of stock heads."
Personally, and this is just me, I'd just as soon start out with the best deal GM has going in iron-heads, rather than hope to get up there after a lot of machine work that costs nearly as much. I mean, the guys at the machine shop I went to turned down all of that labor on my original heads when I brought them in - they said those castings would never crack but that's all they've got going for them, I'd be better off putting the money into new heads.
Old 08-21-2002, 01:34 PM   #17
WB72
Before and After
WB72's Avatar
Will any V8 Vortec head fit on a SB?
Are there different types or casting numbers that are better than others?
66,000 miles.
Alberta, CANADA
Old 08-21-2002, 02:12 PM   #18
terrylee
Vortec Heads
I had found a site on the internet to a GM auth place that sold Vortec heads for around $200/set. I have to see if I can find it again. This was about 2 years ago. I cannot remember, but there is big block Vortec heads too right?
terrylee is offline   Reply With Quote
Old 08-21-2002, 02:25 PM   #19
Snowbound
Snowbound's Avatar
Hey WB72, I also was interested in a set to bolt onto a 400sb. GM Canada wants something like $500 each for them! Check out ScogginDicky Parts on the web, they are the cheapest I've found. Or look into some used ones from a wrecker. There's a wrecker in Edmonton - I think it City Auto and Truck Parts that had them for about $300 /pair. It's been a while though and I find that the prices vary from day to day at the yards. Good luck!
Brian
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600
Snowbound is offline   Reply With Quote
Old 08-21-2002, 02:37 PM   #20
Project1970
14.1 @ 96MPH
Nope, I'm almost 100% certain that a Vortec head is a Vortec head. Tough suckers, too; my mom has a set in her '97 Suburban and that thing has yet to see an easy day in its life. Still running hard after 92,000 miles.
Old 08-21-2002, 03:02 PM   #21
Blazer1970
Blazer1970's Avatar
There are 305 versions of the Vortec heads also, so if you are shopping for used you don't wan't to end up with those. They have a smaller combustion chamber, and I am not sure what other differences may exist. The assembled L31 heads are GM part # 12558060. Casting should be 10239906 or 12558062. I have never heard any definitive answer to the question about the 454 version of the Vortec head. Most later model truck 454s used a "peanut port" type of head that is not really performance oriented, but I am not sure about the 454 Vortec motors. The assembled L31 heads started out on the market at about $200 each ($400/pair), and the best price you will find now is closer to $250 each. They have never been available for anything close to $200/pair.
Blazer1970 is offline   Reply With Quote
Old 08-21-2002, 03:12 PM   #22
terrylee
That price that i listed was for the SB's. I didn't know if there was a BB version.
72 Super 402BB/TH400
Baby on the way!
Old 08-21-2002, 04:01 PM   #23
Blazer1970
Blazer1970's Avatar
The prices I listed are also for SB heads. I have never seen the BB Vortec heads for sale, but they obviously exist, since there was a "Vortec" 454 used in trucks. L31 is the RPO for the SB 350
Vortec engine.
Old 08-21-2002, 04:51 PM   #24
white68chevy
I have been running a set of these heads for a little over a year. I love them they make a great street power, not to much but enough to have fun with.
1968 swb
IM-Bufechevy56
If its to loud then your to old
white68chevy is offline   Reply With Quote
Old 08-21-2002, 05:20 PM   #25
superchevy
Got big-block?
superchevy's Avatar
I just bought a set of used (15,000 miles) vortec's off a '98 Suburban for $300 including rockers arms.
I'll be putting them on my '93 as soon as I get my vortec intake with egr from gmpartsdirect.com
I'll post pics of the install.
SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
