Old 12-13-2006, 07:19 PM   #1
CMars45000
CMars45000's Avatar
Wo runs an MSD distributor?
I am getting ready to buy ignition components for my 327 and I am lost between the different Pro-Billets. They have the Pro-Billet Ready-to-Run, The street pro-billet, the pro-billet, and teh pro-billet HEI.
I am going to be running a MSD Digital 6 box. I am torn between the pro-billet and the street pro-billet. What are the advantages of having/not having vacuum advance? What are the disadvantages?
This engine will see the high side of 7,900 rpm with a solid roller cam...
I am just trying to get the best dist. for my setup...
opinions?
thanks
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 12-13-2006, 07:36 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: Wo runs an MSD distributor?
the pro billet dizzy is for a race engine with a very lumpy cam where you might have your timing chain gears advanced or retarted to have timing built into a engine..thus no need for a dizzy vacuum advance pod
on a stock to mild built engine..a vacuum advance is the way to go..
on my 496 hyd cam engine with a lumpy cam i have no vacuum advance on my pro billet dizzy. but i run a double pumper carb..
on a engine with a carb that runs vacuum secondarys thats mildy built a vacuum advance helps the carb and engine work together..
8000 rpm's a lot of rev's..this engine better be built like a mofo. to withstand that with aftermarket rods pistons,crank, arp bolts, balanced,sfi everything,,heads, ---stort term----engine.
anyway good luck..mark
rage'nrat638 is offline   Reply With Quote
Old 12-13-2006, 07:43 PM   #3
CMars45000
CMars45000's Avatar
yeah it is build on the high nickle block, forged 3.25" crank, Manley H beams 6" rods with cap bolts, Ross pistons, Brodix Heads with 2.02/1.60" manley Pro Flow Valves, Comp 289 solid roller cam...
should be a runner I hope...
thanks for the input....
that cleared things up for me a lot...
Vehicles/Projects:
-Aristotle
Old 12-13-2006, 07:50 PM   #4
Jtrux
I'm a poor spectator
Jtrux's Avatar
I have the pro billet with the vacuum advance and I love the adjustablility of the whole system. I run the 6AL box and the blaster coil with matching wires and have never had a problem.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 12-13-2006, 07:51 PM   #5
rage'nrat638
sounds like a non vacuum advane model is where you need to be...
sounds like a killer engine
heres a picture of the 638 ci dart block with a 6al box probillet dizzy 1250 dominator carb
the box on the right is a msd multi function controll box that lets you adjust timing to each cyl. launch rpm's a ton of stuff..
20,000 engine .. no need for a whimpy vacuum advance pod
lets see soime pictures
Old 12-13-2006, 07:51 PM   #6
lilpup69chevy
67-72 parts finder
lilpup69chevy's Avatar
i would want the vaccum advance on it if it were me, on my race car i just advanced the timing and locked it in place with no advance, but it was not a daily driver whatsoever
1969 chevy shortstep 2wd (under construction)
1981 chevy scottsdale lwb 2wd (parts chaser)
2004 pontiac gto (daily driver)
2004 pontiac grand prix gt (the ol ladys car)
1985 chevy short wide
1970 chevy c10 lwb (another parts rig)
1969 gmc lwb (rainy day project)
1968 chevy lwb c10 250 I6 3 spd (soon to be swb)
lilpup69chevy is offline   Reply With Quote
Old 12-13-2006, 08:40 PM   #7
ghackett1
68 C10 Longbed
ghackett1's Avatar
That engine is awesom. Real nice job. I do have one comment though, why are you still running a mechanical fan? An electric set up would be good for another 12 to 15 HP.
ghackett1 is offline   Reply With Quote
Old 12-13-2006, 09:32 PM   #8
Trey`
Active Member
Trey`'s Avatar
I was thinking the same thing. That and what does the rest of the truck look like, Nice engine.
Trey` is offline   Reply With Quote
Old 12-13-2006, 09:36 PM   #9
rage'nrat638
ok well with 850 hp. 10 hp one way or the other don't make much difference..
it also has duel electric fans with that manual fan..
two trans coolers....
heres my 69 c20...thats what i tow the other with when needed
