12-13-2006, 08:45 PM | #1 |
Gas gauge help
I'm sure this has been posted a gazillion times BUT, I got way too many returns when I searched gas gauge,So lets go for a gazillion & one. The gas gauge reads 3/4 full when it's full(better that way than the other way)How can I fix it? It's an aftermarket blazer tank.
12-13-2006, 09:23 PM | #2 | |||
Union Electrician
Re: Gas gauge help
easiest and cheapest thing to do would be to replace the resistor on the back of the fuel gauge.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
12-14-2006, 12:53 AM | #3 |
Re: Gas gauge help
If the resistor doesnt do it then take the sending unit out and clean the contacts on the reostat.You can use a FINE fingernail file to clean off the gunk that may have formed,then reassemble and try it out.Make sure that you spray off the contacts with carb cleaner or better yet use electrical contact cleaner.If thats not it then it could be that the arm that holds the float is bent.
12-14-2006, 01:19 AM | #4 |
Re: Gas gauge help
Float Arm is the culpret!!!!!!
Without breaking it, try and bend it until you get the correct reading
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
12-14-2006, 01:44 AM | #5 |
its all about the +6 inches
Re: Gas gauge help
12-14-2006, 05:02 AM | #6 |
Re: Gas gauge help
I thought I read something about ohms & what they should be or something like that.As far as gunk that's not it it's a brand new tank & float.Kinda hate to just start bending the arm & that not be it.
12-14-2006, 08:48 AM | #7 | |||
Union Electrician
Re: Gas gauge help
That is why I said to change the resistor on the gauge itself. I onl know of two sending units for the repop blazer tanks and they are rated at 30 ohm 63-66 and 90 ohm 67-72. You can use an ohmeter at the tank and try to see what the sending unit is putting out, but if it were mine I would try the resistor. I have a bunch of them here if you want a known good one for $8 shipped I would be more than happy to help you out on this. I would need a couple of dasy to get one tested and verified as I have been very ill this week.LMK...Randy
12-14-2006, 02:30 PM | #8 |
Alright Alright Alright
Re: Gas gauge help
i had the same thing happen. it turned out to be the resistor. i went to fix-a-guage.com and i bought one of their resistors and installed real easy. it was only like 17 dollars with shipping.
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
12-14-2006, 03:06 PM | #9 |
Re: Gas gauge help
I have the exact same problem (I JUST figured this out yesterday, it's the first time I've put a full tank in the truck) It went just a hair past 3/4 full, exactly as you stated your's does. I have an aftermarket blazer tank in a C-10. Without dropping the tank or removing the bed, I can not get to the sending unit, what does the resistor on the back of the gage look like? I might have to take mine apart this weekend!
When the gage is on E, the tank is empty! So that part is working correctly as I have run out of gas a couple times running the truck around the yard before it was completed. That leads me to believe this resistor is the culprit. SO byrd, which resistor SHOULD go with a blazer tank? When I take mine apart, if it's different, I can assume that's what is wrong? I'm sure my tank is a 69-72 blazer.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 12-14-2006 at 03:07 PM. |
12-14-2006, 07:02 PM | #10 |
Re: Gas gauge help
the resistor looks like a little white rectangular piece. the fix-a-gauge piece is universal and works on all applications. i would look into that before you get into the tank.
12-14-2006, 07:15 PM | #11 |
Re: Gas gauge help
the first place to check is the range of motion of the float arm if it doesn't move thru the whole range of motion it's saupposed to a resistor will do you no good except giving you a false reading
12-14-2006, 09:12 PM | #12 | |
Re: Gas gauge help
12-15-2006, 12:42 AM | #13 | |||
Union Electrician
Re: Gas gauge help
Sure just send me a PM to remind me
12-15-2006, 01:00 AM | #14 | ||||
Union Electrician
Re: Gas gauge help
The resistor is the same for the 67-72 truck fuel gauges. The only difference is the repop blazer tank has two optional sending units (that I know of maybe more??)30 ohm and 90 ohm. Now I am positive that you have the right sending unit as you would not get past 1/3 tank or so if you had the wrong sending unit.You could have a dirty/bad connection across the resistor, you can easily just visually check that. If you have an ohmmeter here is a way to check the gauge and resistor using this guide I have posted and that should tell you where you should look. This should done with the ignition off to protect your meter,you do not want to apply power to your meter when it is in the ohms function as you run the risk of damaging it or blowing a fuse in the meter.
12-15-2006, 10:54 AM | #15 |
Re: Gas gauge help
Shoot, so it's probably not the resistor then? At least it's not the wrong one...
Now that I think about it, I remember testing the float on the blazer tank and I could have sworn that it went to E and F when hooked to the gage.... so what the crap is going on?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
12-15-2006, 12:20 PM | #16 | ||||
Union Electrician
Re: Gas gauge help
There is no difference in the resistors, just the sending units. I would really lean more on it being the resistor as you have stated you tried out the sending unit and it worked fine then. I was just trying to suggest the easiest thing to trouble shoot first, as dropping the tank is quite a bit of work and guess I'm a little lazy. I would make sure it is electrically sound before moving onto the mechanical aspect of it. Just my .02. Randy
12-15-2006, 06:43 PM | #17 |
Re: Gas gauge help
The truckandcarshop.com has the resistor new for $10, but u have to pay shipping. Take your multitester to the gas station and plug it into the brown wire and start filling up. If the sending unit is working then you should read 90 ohms full.
My question is what do u do when the unit is sending the right ohms and you have replaced the resistor and it still doesn't work? That is where I am now! ---Mike |
12-15-2006, 08:17 PM | #18 | |
Re: Gas gauge help
12-15-2006, 08:23 PM | #19 |
Re: Gas gauge help
Yeah, it should be lower, plug in the red to the brown wire and the black to a good ground and you can watch it fill up by the ohms. I shouted"cool, i don't need to drop my tank" as strangers looked at me strangley.
This is unbelievable!! I just found info posted here in 2003. All these guys were having trouble with their guage pegged f or empty...the fix? It was the fuse! purple band was blocking the break. Unreal, it fixed mine! ---Mike Last edited by 72GMCburban; 12-15-2006 at 08:46 PM. Reason: new info found |
