Old 12-13-2006, 09:27 PM   #1
bad72c10
bad72c10's Avatar
Fuel Filter Question
Hey guys, I sorta have a fuel problem. There is junk in the tank, we're sure it's rust. I have a filter between the pump and the carb, which seems to completely clear up the junk. Now for the question, can I put a fuel filter between the tank and the pump so the junk can't get to the fuel pump? Thanks, Justin
bad72c10 is offline   Reply With Quote
Old 12-13-2006, 09:29 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: Fuel Filter Question
yes buy a semi clear plastic one ,so you can see when to change it
o yea welcome to the board
rage'nrat638 is offline   Reply With Quote
Old 12-13-2006, 09:37 PM   #3
Aarons72s
I agree. I run 2 filters. The in carb one for fine stuff and one under the cab. I use metal and plastic. Depending on whats in my inventory at the time.
Welcome to the board bad72c10, glad your here.
Aarons72s is offline   Reply With Quote
Old 12-13-2006, 09:47 PM   #4
bad72c10
bad72c10's Avatar
Wow, you guys are fast, lol. Thanks for the quick answers and welcome. I have a feeling that I'm going to be on the internet more now that I found this. Thanks again, Justin
Old 12-13-2006, 09:49 PM   #5
BarryB
BarryB's Avatar
This is funny! Once I found this site. I check it more than I do my email.
BarryB is offline   Reply With Quote
Old 12-13-2006, 09:50 PM   #6
truckdude239
truckdude239's Avatar
I've always been told that running a filter before the pump on trucks with with the pumps on the block is bad i dont know why but i'd say go for it
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-13-2006, 11:32 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It's not detremental, but I don't recomend it.
By causing a restriction before the fuel pump, you are reduceing the pressure, and as the pressure goes down, so does the boiling point. Anyone who has even had vapor lock problems can appreciate NOT lowering the pressure and in hand, the poiling point.
