Old 12-13-2006, 10:38 PM   #1
409biscayne
409biscayne's Avatar
E Brake Cable
Is the emergency brake cable different for short vs lwb trucks , will i need to buy a different one when i shorten my frame ? Brake lines and fuel lines along the frame will need replaced also . Just trying to have the parts ready.
Thanks ............................. 409
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 12-13-2006, 10:43 PM   #2
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Re: E Brake Cable
Your cable can be shortened easily using a common crimping cable clamp. Other lines will need shortening or replacing as things get shorter...and cooler! Keep us updated as you move along.
PICKMUP is offline   Reply With Quote
Old 12-14-2006, 12:30 AM   #3
Brad
Out of the carpool lane.
Brad's Avatar
Re: E Brake Cable
Here's what the place that did my shortbed did. However, I didn't feel that was safe with a driveshaft spinning around 3500 rpms close by. Not only that, but I had other issues with 1 wheel locking up so what I did was to cut it down the center, overlap them and use 4 cable clamps on each side towards the loose ends. It's very strong and I've had NO issues with it.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 12-14-2006, 01:32 AM   #4
409biscayne
Re: E Brake Cable
Brad
Who did the shortening ? Charlies ?
Can-Am Motorsports
Old 12-15-2006, 12:09 AM   #5
Brad
Brad's Avatar
Re: E Brake Cable
Yes. Mighty fine job he does too!
Old 12-15-2006, 12:19 AM   #6
409biscayne
Re: E Brake Cable
Yeah , as soon as the weather breaks i'm headed to Portland , let Charlie work his magic . If it ever stops snowing / blowing .
Can-Am Motorsports
