Old 12-13-2006, 11:07 PM   #1
Jerry8168
Jerry8168's Avatar
hey i have a ? on putting my distribtuer back in
it wasn't in all the way so i took it out so how do i get it back in an how do i get it back on the firing order?
Jerry8168 is offline   Reply With Quote
Old 12-13-2006, 11:23 PM   #2
04Xrider
Registered thread killer
04Xrider's Avatar
Re: hey i have a ? on putting my distribtuer back in
You need to get the number one piston up on top dead center on the compression stroke. Find the number 1 wire on the cap and that is where you want the pointer to land when you get it seated. Number one is the front plug on the drivers side. You can pull that plug and turn the engine over till you start getting compression, then just line up the mark on the balancer with your timming pointer. Somtimes you have to turn your oilpump drive rod with a screwdriver to get the distributor to drop in where you want it.
04Xrider is offline   Reply With Quote
Old 12-13-2006, 11:42 PM   #3
Jerry8168
Jerry8168's Avatar
alright thanx man and i had another question how hard is it to change the front spindles and rear end?
Old 12-13-2006, 11:46 PM   #4
krue
Designated A-hole!
krue's Avatar
Depends on your mechanical ability. Get a haynes manual and it'll tell you pretty much what you need to know for the spindles, the rear end should be fairly straight forward. Be careful, those coil springs (if your truck has them) store a lot of energy.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
