Old 12-13-2006, 11:39 PM   #1
Warrior59
Warrior59's Avatar
Power steering
I have a 1970 chevy c10 the powersteering Is hard to turn one way.Trun to the left it works great but you turn to the right it like you dont have any at all.Any help please.
Warrior59 is offline   Reply With Quote
Old 12-14-2006, 12:35 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Power steering
I'm not to familiar with how these boxes work so I'm just guessing ,but was the box centered when the pitman arm was put on? I was thinking that if it was turned all the way to the right and the arm was installed then the right pressure port might not be opened. I know they have ball bearings inside them but I have never opened one or checked to see how they operate. Did it work and just quit or has it not worked since you got the truck?
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-14-2006, 12:45 AM   #3
Warrior59
Warrior59's Avatar
Re: Power steering
It has not worked while I have own the truck.
1970 chevy custom
Old 12-14-2006, 01:07 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Power steering
I'm not at home till late tomorrow so I can't check any of my boxes to see if they stop internally when turned all the way R or L but if no one has an answer by then I will check. You may just have a bad box. I know that there is only one pressure port from the pump so if you have pressure one way then the pump is good.
VetteVet
