Old 12-14-2006, 12:09 AM   #1
BP68
BP68's Avatar
Need help choosing wheel size!!!
Hey all,
I am in the middle of a frame off build that I hope will be done by Summer next year.
The truck is a 68 Chevy short bed that will have the ECE 4/6 drop kit.
Truck is gonna be a bright med blue metallic with graphite interior. I know how I want nearly every detail of the finished truck, but I just cannot visualize the wheel size. I have looked at probably hundred of pics and just cannot decide.
Considering the wheels and tires will be one of the more expensive parts of the build, I don't want to mess up.
I know I want Foose Nitrous wheels in Chrome, 8" wide in the front, 10" in the rear. I want to keep the same circumference front to rear, rather than say 18's front and 20's rear.
Now do I go 18's or do I go 20's. Unfortunately I cannot buy both and see em on the truck.
So pls post your comments and advice on how to make that call.
Pics would be great, need wheel and tire size suggestions, and also backspacing recommendations.
I am hearing 4-4.5 bksp for the front and 5-5.75 on the rears.
How would the look differ between a 4" backspace and a 4.5"?
Thanks for the help!
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 12-14-2006, 01:12 AM   #2
kyull67
kyull67's Avatar
Re: Need help choosing wheel size!!!
I'm running 18 x 8's all around with 4 inches of backspace. On the stepside the rear tires rub a little bit on the bedsides but I'm not sure about the fleetside beds.
kyull67 is offline   Reply With Quote
Old 12-14-2006, 01:14 AM   #3
centsless
sufficiently talented fool
centsless's Avatar
Im not sure if this will help, but here goes... Mine has a 3/5 drop andfactory Impala SS wheels They are 17's and I think 9.5 wide with 255/50zr17 BFG's
Attachment 230373
Attachment 230380
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 12-14-2006, 01:35 AM   #4
Boise69
The Hammer Man
Boise69's Avatar
Centless... thats sweet. that would definately turn my head.
Boise69 is offline   Reply With Quote
Old 12-14-2006, 09:15 AM   #5
jkade
jkade's Avatar
I am runnning 20x8 up front with 4.5" and a 20x10 out back with 6" if I remember right. The front tire is a 245/40/20 and the back is a 295/40/20. Hope this helps.Name:  Blazertrimlow.jpg
jkade is offline   Reply With Quote
Old 12-14-2006, 10:15 AM   #6
novajess1972
novajess1972's Avatar
BP68, I just tried to send you an email, but it was returned. You might wanna look into it.
Here are a couple links I've used in the past to help with wheel/tire size and backspacing. Just enter current info, then desired wheel/tire info, and it will show variances in real world numbers, such as actual tire height/width, etc. Actual numbers that we need to know to determine if the desired wheels/tires will fit under our trucks.
http://www.rims-n-tires.com/info_spe...20/%20Comparer
Another helpful tire size link.
http://www.1010tires.com/TireSizeCal...?action=submit
I am running 20x8.5 front and 20x10 rear. Backspacing front is 5 inches and 5.5 rear. Tires are 255/45-20 front and 295/45-20 rear. It helps to have more BS on front when you lower it. The more BS, the more inward (toward motor) it will sit, providing more tire-to-fender clearnace. As low as mine looks, you would think that I having rubbing issues when turning, but there are NONE. I can turn the wheels from full lokc to lock with no interference.
Hope this helps.
Jesse
1985 SWB Silverado 1/2 Ton
1972 Chevy SWB 1/2 Ton (sold)
1972 Chevy Chevelle SS (sold)
1971 Chevy Nova (sold)
1967 Chevy El Camino (sold)
2001 Mustang Bullitt (sold)
2019 Toyota Tundra Crewmax (daily)
novajess1972 is offline   Reply With Quote
Old 12-14-2006, 10:59 AM   #7
boraxman
Keepin an eye out
boraxman's Avatar
Love your truck Novajess1972...very nice!
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 12-14-2006, 11:11 AM   #8
novajess1972
THANKS!
