S10 door weather striping
Hey list, I've heard some of you guys say that you are using S10 door seals on you 67-72 trucks. How good do they work and what year S10 seals are you using. Thanks you time and help is apprciated.
J.D. Last edited by Truword1; 12-14-2006 at 08:42 AM. |
67-72 Addict!
Re: S10 door weather striping
They work great and can be had at most junkyards dirt cheap if you are on a tight budget!. Look for Blazers in the late 80's to early 90's.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Hey 70C10, are these the snap on fit or do they have to be glued?
J.D. |
http://www.67-72chevytrucks.com/vboa...ther+stripping
love mine, wouldnt go stock for anything. still nice and tight, small hard pull to close. |
![]() Join Date: Nov 2004
They are push on. I bought a brand new set and my doors WOULD NOT close. The new seals are too stiff. I still want to use them, but I'll be hitting junkyards soon for a "soft" set of used ones. My truck doors have already been aligned, but if they hadn't I would have loosened up the door hinges so the doors would close until the seals softened.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
are the door openings the same size? I would have thought the s10 doors were smaller, thus leaving a portion of the 67-72 opening with out a seal. or is there a small patch portion?
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
cool!!!!
Fabricate till you "puke"
Ill bet a good used set will fit my chopped top 69 just right......if the shop is slow tommorro, I will find out
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
I have got the drivers side on and I had to adjust the door out a little. But it made a huge difference.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Well, I picked up a really decent set of use seals & installed them in my chop top 69.....had to cut about 4" out @ the bottom center as they were a tad too long! The doors did shut VERY stiff, but I think they will settle in over the winters rest(hopefully). If not, the doors may need to be readjusted. The best part was the seals look almost new, & were only 5 clams for the pair
This was not my idea.....but it worked out very slick! The s 10 seals that I put on made my doors very tight (slam to shut). In one of the earlier threads on s 10 seals, one of the other guys suggested tapping in the pinchweld on the cab for clearance.....my doors now shut firmly, but not bad at all. I figure that the winters rest will seat them in the rest of the way. The seals I got were boneyard pcs, but they look new, so I beleive they were replaced at one time. They will come up a tad short for the used pcs in a stock height truck, but they worked out great for my chop top truck....& no more seals slidin off !
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 12-18-2006 at 03:30 PM. |
