Old 12-14-2006, 08:10 PM   #1
turbochevy
1970 Fleetside bed Question
I am getting ready to start some of the body work on my 70 swb truck. I cannot locate a good metal bed bottom, so I am considering going with a wood bed. Is there anyone that has completed this swap, and what was involved?
1970 Chevy C 10 SWB
turbochevy is offline   Reply With Quote
Old 12-14-2006, 08:23 PM   #2
john
member #16
john's Avatar
Re: 1970 Fleetside bed Question
You will have to change cross sills and bed front panel. Check here for full info.
http://www.mar-k.com
john is offline   Reply With Quote
Old 12-14-2006, 08:33 PM   #3
jaros44sr
jaros44sr's Avatar
I took out the metal bed in my Jimmy and replaced with a wood kit. The hardest part for me was getting the metal out. Ended up buying a pair of electric shears (milwaukee) and eazed the pain somewhat. You could use a angle grinder, buy lots and lots of cut off wheels, to noisy for me...
Start at the back of the bed, cut out a cross section between the crossmembers. Start at the next crossmember by drilling out the spot welds when your clear of the crossmember, you can start to cut out another section of floor. I had to replace 3 of the 4 or 5 crossmembers, if you don't have to use them it makes it alot easier. I just tightened the carriage bolts on the bed sides till they snapped, makes it alot easier
I think you'll like the final outcome!! Ask away on the Questions, I'll try to help you out. J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-15-2006, 11:28 AM   #4
turbochevy
Great info, thanks folks!
1970 Chevy C 10 SWB
Old 12-15-2006, 11:35 AM   #5
1967j
1967j's Avatar
if you have acess to plasma cutter cnc you could get a flat metal bed cut out, and then cut out peices to weld on top. Ive seen it done with flames.
1967j is offline   Reply With Quote
Old 12-15-2006, 02:54 PM   #6
72armyswbtruck
72armyswbtruck's Avatar
Someone out there makes a flat bed repair panels don't they?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
