Old 12-15-2006, 01:58 AM   #1
el curioso
el curioso's Avatar
Brake light lit
I recently swapped out the drums to disk in the front end and after changing the complete spindles, proportioning valve, MC and booster, the brake light in the dash stays lit. I have bleed the brakes 3 times, the pads are brand new and the MC is also new. What the heck gives ???
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 12-15-2006, 05:37 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Brake light lit
Oh, in the dash. NM... What 68c10 said.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-15-2006, 07:01 AM   #3
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
Re: Brake light lit
It sounds to me like you need to reset or hook up the switch in your prop valve
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 12-15-2006, 06:12 PM   #4
el curioso
el curioso's Avatar
Re: Brake light lit
It has the wire connected to it. How do you reset.
Old 12-16-2006, 07:57 AM   #5
braggwood
Re: Brake light lit
I may be wrong, but it sounds as if your master cylinder is off center. To center it, have someone pump the brakes and watch the light, bleed it slowly at the line on the master cylinder, when the light goes out tighten the line. Hope this works for you. Greg
braggwood is offline   Reply With Quote
