Old 12-15-2006, 02:47 PM   #1
truckminded
Junior Member
Gears
Hey everybody, right now I have a open diff. w/373's. I bought a complete rear end w/limited slip but it has 307's.do you think I should just put the whole rear end in and run the 307's? would I notice any differance?
truckminded is offline   Reply With Quote
Old 12-15-2006, 04:04 PM   #2
soulman67
Randy churchill
soulman67's Avatar
Re: Gears
yep, the 307's will lower your highway rpms, which will probably get you better mileage. It will be a little slower on take off, which depends on your engines power. It might just slow you 0-60 time a half second to a whole second maybe more if your engine is weak.
1983 GMC K2500 6.2 diesel 4" lift on 35x12.50 tires
2008 GMC 2500HD 6.6 diesel 3" lift on 315 75 16X10
2003 Jeep Rubicon 4.5" short arm lift
1985 Jeep CJ7 30k in parts and still adding up
soulman67 is offline   Reply With Quote
Old 12-15-2006, 05:59 PM   #3
Rick Mills
Rick Mills's Avatar
Re: Gears
Oh you'll see a big difference. Especially light to light.
If you're doing a lot of city driving you may not notice much change in the gas mileage, but highway driving will improve.
The Fastor Pastor
'68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed:
'70 swb; TH-400 - bagged & shaved. Looking for new engine or parts.
Wife - Original {A Real Classic!}
Rick Mills is offline   Reply With Quote
Old 12-15-2006, 06:23 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Gears
highway revs will seem almost like an overdirve... if i remember right, 65 is right at 2400 RPM with 28 inch tall tires.
Old 12-15-2006, 08:41 PM   #5
truckminded
Junior Member
Re: Gears
I am real happy with the way it is now. I dont want to loose power out of the gate.I think I'll wait and find sombody to show me how to put the eaton in my carrier & use my gears.MY truck is 72 1/2 ton gmc 5 lug, the other rear end is 72 1/2 ton chevy 5 lug. Theese should trade right I dont know why but the chevy looks smaller.mabey I am seeing things again.
Old 12-15-2006, 10:35 PM   #6
BCOWANWHEELS
Re: Gears
It Will Be A Dog On Takeoff And A Super Dog If You Tow Or Haul. And Your Speedo Will Be Off Also.
BCOWANWHEELS is offline   Reply With Quote
Old 12-15-2006, 10:35 PM   #7
wolfthing2000
Re: Gears
4.56 would be loads better for take off!!!
Just kiddin!! I had 3.07s in a 76 with 350 and 350 and it was perfect with 32 inch all terrains (4x4) Not a dragster for sure off line but it was a good all around gear.
wolfthing2000 is offline   Reply With Quote
Old 12-15-2006, 11:33 PM   #8
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Gears
i have a 72 with stock 350 (175hp i think) and 350 tranny and 31s(thats what it says on the sidewall) with the 3.07s and mine runs fine and if i had more hp it would drag fine ofcourse thats on the street but still, and if urs is a DD the 3.07s will actually be an improvement
-steven
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 12-15-2006, 11:44 PM   #9
68C15
blood type; Retumbo
68C15's Avatar
Re: Gears
I would go with the 307's as well. mine works great around town and on the highway with 29" tires. the posi may be a bad isea on snowy/iced roads.
68C15 is offline   Reply With Quote
Old 12-16-2006, 12:04 AM   #10
ChevyCrazy67
ChevyCrazy67's Avatar
Re: Gears
If all your after is not losing anything off the line don't go with the 307s
Kevin
1967 C-10 swb fleetside
1968 C-10 stepside
1999 Z71- sons dd
1999 2wd silverado-my dd
2003 Tahoe- wifes dd
ChevyCrazy67 is offline   Reply With Quote
Old 12-16-2006, 12:27 AM   #11
bryanw1968
bryanw1968's Avatar
Re: Gears
3.40 is a great gear in IMHO. I had that setup in my '78/stroker truck and loved it. Right now I'm running a 3.73 and pull about 3200RPM to do 70MPH and it is KILLING me on gas.
bryanw1968 is offline   Reply With Quote
Old 12-16-2006, 10:46 AM   #12
crazy longhorn
Fabricate till you "puke"
Re: Gears
You cant swap the gears from 3.07 to 3.73 without a carrier swap, the 3.07 is a 3 series carrier (gears 2.76-3.42), & the 3.73 is on a 4 series carrier (3.73-4.56). You can get AFTERMARKET 3.73 gears that will fit the 3 series posi that you have tho. IMO, a 3.42 gear would give the best of both worlds, less rpm on the hyway, but also good takeoff. Best of luck, L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
